AIS filterminder problem
Old Jun 3, 2007 | 03:04 PM
tlocklear's Avatar
tlocklear
Question AIS filterminder problem
I installed an AIS in my 2001 7.3L PSD, and the filterminder showed restriction. I put the filterminder from the stock airbox on the AIS, and it doesn't show restriction! What gives? Do I have restriction or not? The two filterminders have different part numbers; (F81A-9N622-AA for stock unit; 2U2J-9N622-AA for the unit on the AIS). The unit on the AIS has a plug for an additional sensor that my truck does not have (restrictor indicator cable?). Has anyone see this problem? The vendor says he would be real surprised if the AIS is causing restrictions, since I have minimal mods (4" turboback MBRP exhaust). I'm familiar with the foam fender sleeve option, and will go this route if necessary, but I'd rather not drill a hole in a perfectly good (new) airbox at this point. If it's giving restriction right off the bat, then I'd say there is a design flaw. I'm hoping it's just a defective filterminder giving me a bad reading. Any feedback would be great. Thanks.
Old Jun 3, 2007 | 03:09 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to Ford Truck Enthusiasts!
You will want to post your question in the tech forums. Just click on the Forums tab at the upper left and scroll over the list. I suggest trying the Super Duty forum but you can also try the 7.3L engine forum. Either way I think you will get some answers to your question in those forums. For local support and information stop in your state chapter. Here is the link: https://www.ford-trucks.com/forums/forum88/
Good Luck!
dnnyklly
New Member Introductions
May 21, 2007 09:13 PM
chazman_1962
May 3, 2007 07:01 AM
jerryelectric
Apr 18, 2007 05:34 PM
ford7.3
Apr 16, 2007 05:06 PM
paintdl
Apr 7, 2007 03:27 PM
