What Does This Control?
Old Jun 3, 2007 | 12:11 PM
PaulzF150's Avatar
PaulzF150
Part #E4TZ12A6-A
It is a relay that is located under the dash. On the PS side of the ash tray. This is om my '85F150, 4.9L, 1bbl carb, C6 Automatic, 4X2, w/ AC.
Does this relay have anything to do with the computer?
Old Jun 3, 2007 | 08:53 PM
Franklin2's Avatar
Franklin2
You could unplug it and find out what doesn't work. I really don't know what it's for.
Old Jun 3, 2007 | 09:04 PM
MikeFlorida's Avatar
MikeFlorida
Is it the fuel cut off switch? does it have a little button on it.
MikeFlorida
fuel cut off relay?
Old Jun 3, 2007 | 09:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by PaulzF150
Part #E4TZ12A6-A
The processor (computer) is Ford basic number 12A650 so the answer is yes, same 12600 group. However, you are missing the rest of the basic number (12A6??), and where is it marked E4TZ? Ford didn't mark parts with the Z unless you are looking at a parts label someone left on the part. Ford only used engineering/casting numbers to ID parts, and used A, B, E. or F (usually) for the last digit in the prefix (E4TA, or B, or E, or F).
Here's the only relay I found with a 12A6xx basic number: ECC Relay ~ marked: E47F-12A646-A1A
Actual Ford part number: E4TZ-12A646-A (Motorcraft DY-443)
NOTE: Anything fuel related will have a Ford basic part number beginning with 9. The fuel related group in the parts catalogs is 9000.
Old Jun 4, 2007 | 02:10 PM
PaulzF150's Avatar
PaulzF150
Thanks for replying everybody. I unplugged the relay and found that the gauges and blower motor will not work. The reason I posted is that there is a crackling sound coming from the relay. This has happened once before as the result of a short. So I am leaning towards the idea that There is another short. I am pretty clueless when it comes to troubleshooting electrical problems, so it is time to bring the truck to the shop.
79highboy150
May 27, 2016 06:34 PM
hmilycar
Jun 11, 2015 07:18 AM
Mike in Ohio
Nov 27, 2012 01:31 PM
thefordguy
1997 - 2003 F150
17
Jul 9, 2010 07:32 AM
89f150mike
Jun 29, 2006 10:26 PM
