block identification #,s
Old Jun 2, 2007 | 01:37 AM
82f350swb's Avatar
82f350swb
when i got this FE ,the lad did,nt know anything about it, bought it ,brought it home (truck & motor $200 ). threw it into my 82, this motor had some work done i,m sure , lumpy idle, really kicks in at 3500 rpm , 750 holley. while checkin TDC . i noticed pistons seemed to be domed. truck will not run on reg. fuel. now that i got 2 yrs on it ,i think she,s tired , needs rebuild. what i,m lookin for is block ID , so i can get proper parts. i always thought it was 76 390 but after checkin some #,s i think its a 66 390.well anyways heres some #,s please correct me if i,m wrong.
intake - d5te9425mb
block - rear - 352 21 , front - 32 352 , rt front- c6me-a , at oil filter 6k27
heads - both fap23843 010 #3 cyl. - c7ae-a (8 bolt ex.)
oh yeah also on block , left side frnt. - 28 diff
thanx
Old Jun 2, 2007 | 02:47 AM
4starcstms's Avatar
4starcstms
https://www.ford-trucks.com/forums/6...s-correct.html
That is a Really good Read, and explains the how and why of ford part numbers
Old Jun 2, 2007 | 02:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
intake - d5te9425mb
thanx
All the 352/360/390 blocks will have 352 on them. it's the basic block for these engines. D5TE = 1975; C6ME = 1966. 6K27 = October 27, 1966. A block cast in 10/1966 would be used in a 1967 and maybe later vehicle, not a 1966. C7AE = 1967. No 360/390's in F Series trucks till 1968.
Old Jun 3, 2007 | 07:02 PM
82f350swb's Avatar
82f350swb
thanx for the info,so she,s a 67 block, 67 heads , 75 intake,with the # i was fugurin it was also out ive a merc.ANY WAYS a couple of more ??, fuel pump is cannister type, went thru 3 so far,(was told fuel pump designed for behind seat tank ) will another pump work e.g pancake style ( saddle tank ) if so what year ?. thanx again
Old Jun 6, 2007 | 10:51 PM
baddad457's Avatar
baddad457
Look at the flexplate, see if there's a counterweight on it. If there is, you've got a 410.
TEX001
34
Aug 9, 2020 07:44 AM
Nick-1973-ford
15
Dec 10, 2016 05:03 PM
Thunderkiss65
Aug 4, 2015 08:19 AM
bad a$$ roth
27
Feb 29, 2012 06:35 PM
BigBad352
Mar 21, 2007 01:04 AM
