93 Ranger XLT
Old Jun 2, 2007 | 11:39 AM
HStorms's Avatar
HStorms
Another option I have is trading my grandpa for his 92 Ranger Custom with a 3.0L But it has 270,000. Runs good still. Dunno what is my better option. LOL
Old Jun 2, 2007 | 11:58 AM
pawpaw's Avatar
pawpaw
Well I don't know wht kind of shape your Grandpaws 92 3.0L is in, but you have lots of new things on your lower mileage 4.0L.
If oil leaks are now it's only problem, seems to me right now it would be wise to try the high mileage oil & see if it'll check up the leaks.
The 3.0L, if geared the same as the 4.0L, will use about as much gas, so there isn't much advantage there. The 4.0L should be more powerful, thus more fun to drive.
How much oil do you figure is leaking out between changes & where are all the places it's leaking from????
Does the 4.0L engine sound ok, no rod. or main bearing knocks???? I know you said, once started, it runs ok, but whats "ok"????
Does ok, mean pretty darn good????
Does it smoke any out the exhaust pipe????
If so, what color is the smoke?????
Old Jun 2, 2007 | 12:06 PM
HStorms's Avatar
HStorms
There is no noise in the engine. It runs damn good when its running. I'm not sur where all it is leaking. I wasn't there. He just said it has a lot of leaks that isn't worth fixing. My guess is that he doesn't want to take the time.
There is a small oil spot under the truck after it has been sitting. Maybe about 2" across, and yes it does have some white smoke out the exhaust pipe when you first start it. Haven't noticed it while i'm driving.
Old Jun 2, 2007 | 12:27 PM
pawpaw's Avatar
pawpaw
Well white smoke after a cold start is normal.
If it's not using any coolant, that would be good.
Blue smoke would indicate it's burning some oil. If the exhaust pipe is oily feeling & black in color, these would be other hints of it using oil.
A dry, brown color exhaust pipe, would indicate the engine is probally still tight.
No smoke while driving, is a good sign.
Sounds like the hot no start problem & oil leaks, are the major concern & if they can be checked up without major outlays of your gold, you could buy some time to decide if an engine swap is worth it.
If you do the engine change, I'd swap the new parts you just installed, off the old engine, to the replacement engine.
Old Jun 2, 2007 | 12:39 PM
HStorms's Avatar
HStorms
Yeah that seems like the only problems. My dad is gonna check into some things. Now that we know the cause we can fix it.
Yeah I will definently take all the new parts off this motor if we do the motor swap.
Thanks for all your help and ideas. I'll repost anything else I find and what we end up doing.
