This one's probably for you Greywolf. You mention brake orientation when flippin axles. I bought my 32' TH with the axles already flipped. I am checking the bearings and brakes and wondered if the brakes were in the correct allignment. The magnet is on the bottom of the assembly. Is this correct?
Bigger question:
As I looked at the brakes I did not see an automatic adjuster on the brake. Normally, on drum brakes, there is a mechanism that adjusts the pads closer to the drum when you back up. Do I need to use a spoon to adjust all of the brakes to the same drag (dating myself here...) manually like in the old days? I would think this would be a big issue if you are talking about the same voltage going to each brake.
Thanks in advance for your help. I read all of your posts and greatly appreciate your insight and advice.
Yes the magnet will be on the bottom and they have to be manually adjusted .
Mel you need to pull apart that wheel that is not working to see whats wrong.
Just make sure the wires have good connection first and if that looks ok you will need to pull the drum off and see if everything is ok.
Sometimes if you have the bearings you can greese with a gun by taking off the cap they can get full of greese if the seal leaks.
Fireoutmatt, I have checked and I am getting good voltage at the magnet. I just dont know witch way to move the star wheel. I guess I will lift the axel and try both ways until I start feeling drag. (2005 rockwood 5er)
Mel it would be a downward action thru the backing plate. If you havn't greesed the bearings in awhile this may be a good time to do some preventive maintance.
I have the brakes one side off now and then will do the other side as soon as I get new magnet retainers. I had to order them nobody stocks parts for the larger brakes . If you haven't had the Dexter Nev-R-Lub hubs off its nice setup and the 3 3/8" brakes are huge compared to the 2" ones. Anyway I will pay close attention what way the other side adjusts but with self adjusters I think they go the same way on both sides, I've been wrong before .
Let me know what you find out. I remember fighting self-adjusting systems with a screwdriver to push the adjusting lever off the star wheel AND a spoon to turn it; lotsa fun!
Steve
I got my parts today and finished the left side (drivers side) and will do the right side tomorrow. Both of the magnet retaining clips where missing on the first side.
I finished the other side today and the adjustment wheel goes up just like the other side. I'm not sure but all you have to do is reverse the adjustment wheel to make it go the other way.
