Need Advice on towing
Old May 31, 2007 | 10:24 PM
kochennv's Avatar
kochennv
Question Need Advice on towing
I have an 04 F250 XLT Crew cab long bed 6.0 Diesel. I am looking at a travel trailer that is 30 Ft. and 9000 pounds. Will this truck be alright pulling up mountains?? Thanks Truck is all stock.
Old May 31, 2007 | 11:53 PM
Triplespeed's Avatar
Triplespeed
you should have no issues pulling 9000 # be sure to use tow haul
Old May 31, 2007 | 11:54 PM
exiled's Avatar
exiled
I've pulled several loads of hay on 32'- 40' gooseneck trails weighing 18,000-26,000lbs. Although I'm not in the mountains but we do have some pretty good grades and not once did I feel lacking. I dont think there get much more air drag than 2 runs of hay stacked double. I only drive 55 mph out of choice, but I have plenty of pedal left and I have passed at 70 mph up hill. I think this is more than enough truck for you.
Old Jun 1, 2007 | 02:00 AM
kgorman's Avatar
kgorman
I pull 10k over the Sierras bone stock, you will be fine. Let it cool down if you plan to stop after pulling hard.
Old Jun 1, 2007 | 03:44 AM
mitchntx's Avatar
mitchntx
My 07 pulls my 10K enclosed trailer just fine, as well. But don't misinterpret that. I know I did reading posts like those before me.
It's not like it pulls it and you don't realize it's back there. It will struggle some with grades and accelerating when compared to unloaded. While that is obvious, it was more than I expected ... a LOT more.
Fuel mileage will suffer tremendously as well. I went from 15/16 combined to 10 on a 1000 mile round trip, loaded. That was about the same as what I got on my big block gas motor.
So, your 6.0 will do just fine, but just don't expect it to cruise along without any worries. You got to get'er spooled up and cooking to make grades. Once you are committed and then attempt to spool up, you have lost so much momentum it will struggle. Again, I'm coming from a gas motor ...
For grades or passing, you have to keep the revs up, above 2500 and closer to 3K to maintain speed or not drop off too much.
Like I said, my old truck works great. I just had to adapt quite a bit coming from a big block gas motor.
HTH
Old Jun 1, 2007 | 06:27 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Check out my Gallery, I tow that monster up over 10.6 mountains at 12% grades, wiht no issues at all, the trailer is well over 14K.
Old Jun 1, 2007 | 07:47 AM
CampSpringsJohn's Avatar
CampSpringsJohn
I would assume a 30 foot trailer will be a fifth wheeler. Make sure you have mirrors that will see down the sides of the camper. I can't tell you how many people I see driving down the interstate pulling a camper and I can't see any mirrors until I get up beside them. You need to be able to see what's going on beside you, and your camper.
Old Jun 1, 2007 | 08:14 AM
kochennv's Avatar
kochennv
Thanks guys. I am going to go look at it today after work.
Nick
Old Jun 1, 2007 | 09:08 AM
JJPMach1's Avatar
JJPMach1
I have a 35' 9,000# 5th wheel. The truck pulls it great. I've been from south carolina to the mountains of PA with it and no issues at all.
Old Jun 1, 2007 | 09:44 AM
utahtom's Avatar
utahtom
I pull a 15,000 lb oversize load (see avatar) in mountainous terrain at high elevation.
The truck is an absolute beast
As briefly mentioned by others, be certain to use tow/haul and keep the rpm's above 2,000 when on steep inclines. There is no need to get a "run" when approaching mountain passes although it is best to hit the bottom of the hill at your desired speed. At 9,000 lbs you should be able to hold whatever reasonable speed you want... I towed 7,500 lbs for several years with an 03 6.0 and found the (speed) limiting factor to be trailer tires not lack of engine power
Old Jun 1, 2007 | 11:20 AM
Headrope's Avatar
Headrope
What is tow/haul (I'm new)?
kochennv's Avatar
kochennv
Thanks Utah Tom.
Old Jun 1, 2007 | 12:20 PM
JJPMach1's Avatar
JJPMach1
That's the little button on the end of the auto trans shifter that changes the shift points of the tranny
Old Jun 1, 2007 | 12:30 PM
dchestnut's Avatar
dchestnut
From my understanding, tow/haul mode will help prevent the transmission from shifting excessively. Basically, it will hold a gear longer so it doesn't shift, then shift back if it starts loosing pull. Frequent shifting is one of the things that will kill your transmission, as well as tranny slip.
Old Jun 2, 2007 | 08:06 AM
Deluxe05's Avatar
Deluxe05
Just to add to what dchestnut stated, the Tow/Haul button puts the transmission controller & PCM into a slightly different strategy mode. The primary purpose of this is to lock up the torque converter more frequently than it would if you were not in Tow/Haul mode. The Tow/Haul logic also dictates that if the transmission does downshift, that it will hold that lower gear longer before shifting up to the next higher gear.
This will minimize wear on transmission components and the excess heat generated by the torque converter slippage. It also helps prevent what most call gear "hunting" or "seeking"; wherein the transmission will continually down shift for a bit, then up shift for as little as a couple seconds before down shifting again.
Now, having stated that, I seem to remember reading somewhere that this also caused the clutch fan to kick in earlier to help prevent heat spikes/build-up while towing with a decent/large load. I have not found anything to support or debunk that in the Ford literature though.
