Carb Adjustment
Old Jun 11, 2007 | 10:54 AM
Freightrain's Avatar
Freightrain
Glad you found the problem. It usually comes down to something simple/stupid. Just have to go thru all the checks to find it.
Old Jun 11, 2007 | 01:58 PM
Bear 45/70's Avatar
Bear 45/70
Are you saying you have 20" of vaccuum at idle to the distributer?
Old Jun 11, 2007 | 09:49 PM
LedheadELH's Avatar
LedheadELH
hey guys, I have a carb. problem. it's not one of the simple autolite tho It's on a foreign truck. BUT, it's all the same concept really. It will pretty much ONLY run w/ the choke almost all the way on. but of course it has no power at all that way. If I open the choke up, it won't run, and it's like it's not getting gas, w/ the choke on, it can pull the gas through though.
I've been trying to find a vacuum leak. so I disconnected and plugged EVERYthing w/ vacuum except for the dizzy advance, and the brake booster. and it has helped, but not much. I've sprayed ether around the intake gasket, and carb base, and nothing happened. so I'm stumped.
One more detail, the 4th cylinder has no compression, and it is mostly because of a burned valve, could that cause me to have no vacuum? tomorrow I'm gonna take the spark plug out and run it that way, Ground the plug wire of course so I don't kill the coil. and maybe not having any compression, or another way for the air to move it MIGHT help me out......maybe???
what do you old heads think, you've def. been around this MANY years more than I have.
bfricks
Dec 20, 2016 02:33 PM
yabadaba
May 15, 2016 10:29 AM
Heesman
Sep 5, 2014 03:00 PM
frank83fire
Mar 20, 2009 03:38 PM
LTTLMAN
Jan 26, 2005 03:07 PM
