carb trouble?
Old Jan 26, 2005 | 12:29 PM
LTTLMAN's Avatar
LTTLMAN
carb trouble?
I recently put a 302 into my 78 F-150 4X4. The motor is one I had in another truck and has always been a good performer. When I changed motors I changed the choke over to a climatic choke. It had a manual choke on the other truck. I have started having problems with the carb flooding very easily and running very rough. During a cold start, you can really smell gas. After it warms up it runs better, but still a little rough. It will flood very easy when warm. It seems like the float is not working properly. Upon checking out this carb I found that the guy who owned the truck before me, put a carb from a 390 on and jetted it down. I obtained a carb that is for a 302 (a champ reman). There are different vaccum connections on it, than what was on the other carb. Would anyone know where I can find a good vaccum diagram? I appreciate any and all assistance. Thanks!!
Old Jan 26, 2005 | 01:01 PM
rainbowATF's Avatar
rainbowATF
Check autozone website under repair info; emissions; vacuum diagrams for your hook-ups
Don't assume rebuilt carb means good or fixed
I recently went through 3 remanufactured carbs (MC 2150 for 351M) b4 I solved my problems of cold starting, flooding, and hesitation. The first two had either bent throttle linkage or poor acceleration and leaking. The third carb at least idled and had good vacuum. Poor warm-up and hesitation were its problem. This what I found.
1) Bent Fast Idle screw lever; did not come anywhere near fast idle cam: straightened and adjusted per rebuild kit
2) Choke unloader vacuum can leaked and full of gas: replaced with new $24
3) Air Metering rods bent and dirty with varnish: replaced with parts from core
4) No gaskets on air metering system: replaced with rebuild kit
5) Power Valve leaking: Replace with kit. Two gaskets found on power valve; old torn one and new gasket.
6) Accelerator Pump would not react to lever adjustment; spring was corroded and bent(squashed); replaced with spring from core.
7) Mixture screws at 4 and 2 turns respectively; instructions say 100% flow bench tested?????
Now it works great; but these carbs are hardly what one could term remanufactured or rebuilt. $244 for carb + $20 rebuild kit + $24 choke unloader + labor. The auto parts clerk summed it up; "I hate to sell this cr*p!"
Old Jan 26, 2005 | 01:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello, Welcome to FTE!
Your post has been moved to the proper forum.
Please turn your email system ON, your email address is not visible to users.
Please take the time to read the headings and "Read First" notices in each forum. The FTE board is HUGE! We want users to be able to find answers to their questions so it is organized into many areas and search tools are provided.
Please take the time to look around the various forums available. While you are looking around you may find out all kinds of interesting things!
Please avoid cross posting. Post your question in only ONE forum if you don't find that your question has already been answered.
If you have any questions please feel free to contact me.
Thanks for using FTE!
Old Jan 26, 2005 | 02:26 PM
LTTLMAN's Avatar
LTTLMAN
I haven't put the remanufactured carb on yet. It has more vaccum connections than the one that is on the motor, and I want to make sure that I get it hooked up right.
Old Jan 26, 2005 | 03:07 PM
LTTLMAN's Avatar
LTTLMAN
I checked autozone and found vacuum diagrams for 76, 77, 79 thru 83 but none for a 78
CMax1981
13
Oct 24, 2014 05:45 AM
sledhed15
Aug 9, 2007 07:37 PM
nuwave
17
Jun 11, 2007 09:49 PM
ant truck
Sep 14, 2004 11:19 AM
