1961 F150 underdash components
Old May 30, 2007 | 10:35 PM
nyrigids's Avatar
nyrigids
I'm doing a restoration on a 1961 Ford F150 and need diagrams of the under dash components of the heating and ventilation system inclusive of air door linkage and such. I have scoured the internet but have not found anything that has what I'm looking for. Can someone provide some direction, or does anyone have any saleable literature relating to my needs?
Thank you in advance.
Old May 31, 2007 | 10:37 AM
Lui's Avatar
Lui
Have you tried EBAY? I found all service books for my truck there. Good luck
Lui
Old May 31, 2007 | 11:19 AM
nyrigids's Avatar
nyrigids
Thanks for the reply.I've tried a few publications that indicated that they might contain underdash components but have had no success. One such manual was supposed to be specific to interior parts but wound up containing a lot of weatherstrpping parts and such.
Old May 31, 2007 | 03:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Here you go...hipoparts.com.
Order a CD copy of the 1957/63 Ford truck parts catalog. You want pictures? You couldn't ask for a better ref than the parts catalog. Heater pictures are in group 18; wiring in group 14; ventilation system-body group 000; door and window parts-group 200; interior trim pics-in soft trim section.
btw...you have an F100, there were no F150's till the mid 1970's.
Old May 31, 2007 | 04:27 PM
daveengelson's Avatar
daveengelson
If have not already done so them let me welcome you to FTE. Purchased the "1965 Ford Truck Body/Interior Assembly Manual" and gets into the nuts and bolts of the truck assembly. Also gets into spec's as to location and type sealant for seam caulking application. Purchased thru FTE Motorhaven few years back but appears they have changed format and now unable to find literature, and or manuals. On the back it indicates the manual is reproduced by "jim Osborn Reproductions Inc." a licensed Ford Company Product. Here is website if interested. Not sure if anything comprobable thru CD as mentioned. Could try and scan couple pic's but not likely will they be legible. Also, computer illiterate and questionable if I would be able to get them posted to thread or my photo gallery.
http://www.osborn-reproduction.com/c..._Position=PAR:
dave
Old May 31, 2007 | 04:28 PM
nyrigids's Avatar
nyrigids
Thanks very much for the lead, and yes you are correct about it being an F100. My bad. I'll let you know how it works out
Old May 31, 2007 | 04:30 PM
nyrigids's Avatar
nyrigids
Thanks Dave. I will check your info out as well.
Mitch
Old May 31, 2007 | 04:35 PM
nyrigids's Avatar
nyrigids
Dave,
That was the manual I had eluded to in my first post. The isn't any detail of the ventilation system. Mostly sealant related info.
1961FORD4x4
13
Nov 18, 2022 10:00 AM
David56
Apr 16, 2013 06:56 PM
LM14
Aug 4, 2009 07:47 PM
todder53
Apr 8, 2002 10:24 AM
Bushwacker
May 7, 2000 10:45 PM
