ATS housing, remove turbo?
Old May 30, 2007 | 09:27 PM
Ford79's Avatar
Ford79
I'll be getting an ATS housing Friday and want to know if the turbo has to come off to install it. Would it be wise to R&R the o-rings anyway, even though they are not leaking (not that I can see anyway) and possibly make it easier to install the housing?
On a side note, my BTS VB showed up today and the rest of my goodies(except the DP, not until 6-4 ) will be here Friday. It's going to be a loooooong 2 more days at work.
Old May 30, 2007 | 09:35 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Nope, this from ITP Diesel:
While the ATS Ported Shroud Compressor Housing may cost more than other methods of fixing Compressor Surge (like a new compressor wheel), changing to the ATS housing doesn't require removal of the turbo or balancing of the rotating assembly. The savings in removal/installation time, downtime and the labor cost of turbo assembly balancing make the ATS Ported Shroud Compressor Housing an excellent choice for solving your compressor surge problem.
Old May 30, 2007 | 09:38 PM
rbaker6336's Avatar
rbaker6336
seems it would be fairly easy to install without removing turbo
Old May 30, 2007 | 09:59 PM
NS F250's Avatar
NS F250
Does the ATS housing add power? Or just control the surge?
Old May 30, 2007 | 10:09 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Well i installed my ATS housing with the turbo on the truck. However i did manage to overtorque the bolt at 7 o clock that holds the compressor to the backplate. I just left it at that and when i pulled the turbo later to do donuts i put a bolt and nut in there. Make sure you are careful retorquing the bolts, to 200 in/lbs or 17 ft pounds, take your pick. I have a few pics of the install if you would like.
It does add airflow, and does cure surge. You could say it gives power. It looks a hell of alot cooler.
Old May 30, 2007 | 10:13 PM
Tenn01PSD350
I don't believe the ATS claims to add power, but when your turbo flutters, I can't see much power being made there. It is not yet a big enough problem for me.
Old May 30, 2007 | 10:16 PM
Orezona's Avatar
Orezona
I installed my ATS a few days before going on vacation. Pulled the TT 2k miles to SW Arizona. Absolutely no surge and egt's are better. Pulled two or three real western 6%ers with a bad cross wind. Last year without the ATS the surge was miserable. Next, Spearco IC....
Old May 31, 2007 | 09:12 PM
Ford79's Avatar
Ford79
Thanks guys. Kris, I've checked your pics and thanks for the torque tip.
I was getting surge with the Superchips tuner, unloaded, so the ATS housing was a "must" with the DP chip.
