1966 - 1977 Early Broncos
tires
Old Aug 21, 2001 | 09:31 PM
69BRONCO's Avatar
69BRONCO
tires
I have an uncut 69 bronco, and i want some knobby looking tires. I dont know much about tires ( except they are made of rubber) so i am asking you guys. What will fit, look good, have some nice grip for mild off roading, and hum when i go down the road. I also like the words mickey thompson on the sides of tires but could live with out it. also what should i expect to pay and are there any pictures of some tires?
Old Sep 3, 2001 | 11:57 AM
ROUSHRACING's Avatar
ROUSHRACING
tires
FOR AN UNCUT BRONCO, YOUR NOT GOING TO BE ABLE TO GO VERY AGGRESSIVE, DUE TO THE FACT THAT MANUFACTURERS DON'T MAKE AGGRESSIVE TREADS FOR SMALL TIRES, I THINK YOU CAN GET SOME 30'S OR MAYBE 31'S UNDER IT, I WOULDN'T GO MUCH WIDER THAN 10.5, YOU'LL HAVE RUBBING OTHERWISE, OR YOU COULD CHECK A FEW OF THE E.B. WEBSITES, (BRONCO.COM, JEFF'S BRONCO GRAVEYARD, JAMES DUFF, THERE ARE A TON OF THEM OUT THERE AND I KNOW I FOUND ONE THAT HAS TIRES SIZES FOR E.B.'S AND IF THEY ARE LIFTED AND WHAT NOT! GOOD LUCK! OWNER OF A 72' E.B. NATE!!
Old Oct 30, 2001 | 03:02 PM
Phaeton16's Avatar
Phaeton16
tires
For an uncut Bronco with stock suspention, you're pretty much limitted to a 31" x 8 tire. As for recommendations, it depends on what you're going for. If you want the "knobby" look but drive mainly on the street, I would check out the BFGoodrich Mud Terrain T/A. A good source for tires is The Tire Rack, at www.tirerack.com.
Regards,
J.B. Hebert
Old Dec 27, 2001 | 02:56 PM
eclectix's Avatar
eclectix
tires
I had a similar situation (68) but finally
after about a year's worth of consideration
decided to cut, lift and go with 10 x 35's.
It was a leap of faith for me that I would
be happy with the results, but after all
(or at least most) of the problems I ran into
got straightened out, it was OK. The
convincing argument to me was that from
an engineering viewpoint, the uncut fenders
were absymally inappropriate for larger tires,
which are needed (in my case) for better
gas mileage as a DD as much as for going
offroad and overcoming obstacles.
Old Mar 21, 2002 | 09:25 AM
gmurrell's Avatar
gmurrell
tires
:-staun how did you get better gas mileage with larger tires?
Old Mar 21, 2002 | 09:58 PM
BroncoSteve's Avatar
BroncoSteve
tires
I run 33 x 9.5's on my uncut 70 model EB, but I have 2 1/2" of suspension lift and 1" of body lift. As stated above, your pretty much limited to 30's or skinny 31's without flares or lift. Your best bang for the buck is going to be the BFG's. They got three different styles now. Good luck, Steve
Old Mar 24, 2002 | 10:28 AM
69BRONCO's Avatar
69BRONCO
tires
after all is said and done, it just looks better, and you can do more with the bigger tires. I cut em out, flared them, and put on some goodyear wrangler mtr owl's that are 33 X 12.5. they look, and perform awesome, and fit great with no lift. thanks
Old Apr 17, 2002 | 04:23 PM
plumbronco's Avatar
plumbronco
tires
I have a 77 bronco with 235 X 75 R15 tires and stock rims. No rubbing at all and the speedometer is still acurate within 4 mph.
Check out the BFG Mud Terrain KM. They look real good with the new tread design, hum when you go down the road, (but not annoyingly loud) and have good wear characteristics on the pavement.
By the way, 31 X 10.50 tires on stock rims have about a 75% chance that they will rub the lip of the fender.
One mans opinion.
Dave.
Old Jul 12, 2002 | 01:58 PM
flpanhead's Avatar
flpanhead
tires
If you want aggresive tires that hum in a small package, go with Buckshots. They are loud and they make them in sizes from 29" to 33". They are narrow so they will fit without a lift or cutting. They are made by Gateway. If you want an aggressive mud tire you can't beat them and they last forever due to the hard compound. Good luck!
Old Jul 15, 2002 | 09:27 AM
44dwarf's Avatar
44dwarf
tires
goosehunta
Mar 14, 2011 11:38 AM
86sixbanger
Offroad & 4x4
28
Feb 17, 2010 08:31 PM
brownbronco
1978 - 1996 Big Bronco
17
Dec 12, 2006 10:59 PM
bronco351
Jul 15, 2003 10:54 AM
69BRONCO
Jan 6, 2003 10:46 PM
