Tps
Old May 29, 2007 | 01:36 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Tps
Is their any way to check if the TPS is reading accurately without taking it to the dealer? They called today and said the crew cab is ready to go (new trans and pedal assy). Asked if tps read full 100% at WOT this time and they didn't know.....One in the truck only read 75% at WOT when we when for the test drive to see what was wrong with the trans.
Old May 29, 2007 | 05:21 PM
Cuda_jim's Avatar
Cuda_jim
5 volts would be 100% but that doesn't happen 4.5 volts is all you will see on a stock pedal.
Check this out:
https://www.ford-trucks.com/forums/5...ge-on-tps.html
BTW: If you are using an AE scanner it won't read 100% either, they are working on a fix for that IIRC.
Old May 29, 2007 | 07:47 PM
79_250RangerLariat
Thanks Jim, I'm going to check the voltage on the one in my 5 speed tomorrow. (It's the one that was in the crew that read 75%). The IIRC is that the scanner that ford uses? I didn't ask, the tech used a labtop.
Old May 30, 2007 | 02:20 PM
79_250RangerLariat
Test results: read anywhere from 3.70-3.75 volts So no where near the 4.5-5 volts to show WOT. Question is how much performance is lost on a 5 speed? I saw what not showing WOT did to an automatic. Any way to adjust the TPS or am I looking at spending another $300 for a pedal assy?
Old May 30, 2007 | 03:15 PM
Cuda_jim's Avatar
Cuda_jim
It's going to be the same loss for a 5 speed too. The TPS is the only link to the engine that regulates the fuel and boost. It's like putting a 1 in spacer under your gas pedal on your gasser.
You can try using WD40 and clean it. Search the diesels forums for pedal mod. It may help you get that extra voltage out of your pedal before you go and spend $300 on a new pedal. You might have luck just getting the sensor instead of the entire pedal assy. IDK
Here's some part #'s
Throttle Assembly (Includes Pedal, TPS, & IVS) 94-97
(Ford) F5TZ-9F836-A (f-Series) 94-95
(Ford) F6TZ-9F836-AA (F-Series) 96-97
(Ford) F5UZ-9F836-B (Econoline)
TPS (Throttle Position Sensor) 94-97
See "Throttle Assembly" (May not be Available Individually)
(Ford) F2TZ-9B989-C (recently available, haven't confirmed it works yet)
JNM76
13
Dec 20, 2014 03:13 AM
e3507.3idi
22
Aug 11, 2014 12:07 AM
glovemeister
Aug 4, 2013 01:04 AM
Cage Fighter
Feb 5, 2011 08:10 AM
Jrock909
Jul 29, 2006 02:00 PM
