tps problems
Old Jul 24, 2014 | 10:17 AM
e3507.3idi's Avatar
e3507.3idi
Exclamation tps problems
ok here is what I have 1989 e350 7.3 e4od ambulance package I have 5.06 volts bottom wire top wire 0 volts center wire 1.19 volts 4.48 volts wot just replaced the tps and now it wont shift when I put the scanner on it says tps voltage is to high now that I have replaced the sensor the trans will not shift rt and bounces back and forth between gears prior to replacement tranny shifted fine any help or suggestions for this problem would be greatly appreciated ty and yes I did search this problem and followed all suggestions there this just has me stumped and ford wont even give me a quote to have the tps adjusted they just keep saying it will be 108 a hour and said well it could take a couple hours too get it done I personally think that's a little out of the ballpark not only on the time it should take but also hourly rates
need help asap need truck for work no truck no work for me!!!!!!!!!
Old Jul 24, 2014 | 12:35 PM
e3507.3idi's Avatar
e3507.3idi
where can I get a gauge boss for setting the tps sensor that is what my scanner is asking for
Old Jul 25, 2014 | 10:59 PM
speedwrench72's Avatar
speedwrench72
check that the tach sensor wire is not corroded, and some PCM's are sensitive to voltage, try the original set point of 1.1 volts at what speed is the eratic shifting? try turning on your flashers ( this keeps the converter in the unlocked mode) and drive the rig, can you manualy shift the trans?
Old Jul 26, 2014 | 07:53 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
4.48 V @ WOT is too high.you want 1.2 V idle and around 4 v WOT.
https://www.ford-trucks.com/forums/1...ions-only.html
oh no,im wrong.my bad.it's just iv never been able to get up over 4V WOT while maintaining the 1.2V idle myself.try and tweak it to read 1.2V/4.0V and see how she likes it.
Old Jul 28, 2014 | 11:01 AM
e3507.3idi's Avatar
e3507.3idi
the erratic shifting varies every time you drive it this e350 has no tach with 4 ways on it acts the same
Old Jul 28, 2014 | 11:10 AM
e3507.3idi's Avatar
e3507.3idi
ok just noticed a small puddle of trans fluid under the truck from the front pump seal could the loss of fluid pressure be part of my problem I ordered the seal will be here today going to try installing the new seal to prevent trans from going bad I love this truck just want it to run and drive as it should
Old Jul 28, 2014 | 11:56 AM
e3507.3idi's Avatar
e3507.3idi
Unhappy tps problems
ok I just did some more adjusting late shift from 1st to second but then from 2 to 3 and lockup stacked right on top of each other by 35mph then hits over drive at 55 to 60mph koeo idle 1.2 koeo wot 4.0 volts this thing is very touchy also just added a photo of the rig on my album
Old Aug 4, 2014 | 11:55 AM
e3507.3idi's Avatar
e3507.3idi
ok I am at a loss I unhook my tps sensor and then the trans will shift also the trans will shift until u put about 8 miles on it and then it will not go thru the gears will stay in first gear and then it feels like it is slipping let it sit for awhile and then it shifts again I unhooked the return line to check to see if the pump was working or not and it took about 5 mins to pump out all the fluid could it be possible that I am experiencing a intermediate pump failure
Old Aug 4, 2014 | 07:48 PM
FORDF250HDXLT
if it doesn't have a tach,then how can the E40D trans know what rpms the engine is at? do you mean it has a tach sensor for the trans but just doesn't have a gauge? if there is no gauge then when the sensor frigs up with no flashing od light (like the 92-94 has) then you would need to read the codes to know if the tach sensor was working or not i guess? man.id find a gauge.
actually,what codes are you getting? i skimmed back through and i don't even see them?
you unhooked the trans cooler line and let it pump out all the fluid? why did you do that? how much time did it take to get a quart would you say?
Old Aug 5, 2014 | 05:49 AM
e3507.3idi's Avatar
e3507.3idi
to get a quart I would say over a minute. I pumped it out to replace the fluid and to drop the pan to check the filter to make sure it didn't drop out no gauge in the cluster idk ask ford why they didn't put in a tach theres not even a spot on the dash for it and codes 63 93 29 syptoms are as follows fast shift then a no shift loseing reverse then it comes back losing all forward gears no od unless u put it in n then back to drive then when u loss the gears if u let it sit for 20 mins they all come back
Old Aug 5, 2014 | 08:15 AM
e3507.3idi's Avatar
e3507.3idi
Originally Posted by e3507.3idi
to get a quart I would say over a minute. I pumped it out to replace the fluid and to drop the pan to check the filter to make sure it didn't drop out no gauge in the cluster and codes 63 93 29 symptoms are as follows fast shift then a no shift losing reverse then it comes back losing all forward gears no od unless u put it in n then back to drive then when u loss the gears if u let it sit for 20 mins they all come back
what I have done so far { new tps sensor new vss sensor new neutral safety switch / gear selector new wiring harness and all plugs cleaned all connections tps set at 1.2 koeo idle 4.50 set according to 186a speedo is accurate and steady new batteries alt tested and good full trans flush and new filter no metal in pan every time I scan the truck i will get either a code 11 witch means all good or I will get different codes each time
Old Aug 5, 2014 | 09:04 PM
e3507.3idi's Avatar
e3507.3idi
say bye bye to the tps sensor problem I went out today and I got everything needed to do an Allison swap I go and pull it all out of the donor truck onlything that's not there is drive shaft
Old Aug 5, 2014 | 09:10 PM
FORDF250HDXLT
29 = Vehicle Speed Sensor problem
does your speedometer work properly?
63 = Throttle Position Sensor (TPS) signal too low
do you get the correct 5V at the signal wire with key on? and did you test the ground?
93 = Transmission TCC circuit/solenoid problem
did you inspect the solenoid pack plug?
Old Aug 5, 2014 | 09:33 PM
FORDF250HDXLT
i don't think you've got anything but a few electrical issues to sort out.i believe your a long ways off to take such extreme measures just yet.
Old Aug 6, 2014 | 07:53 AM
e3507.3idi's Avatar
e3507.3idi
speedo works just fine 5.05v bottom wire grond is good even ran a secondary ground to the battery code 63 is why I replaced the tps replaced the vss and the tps and all wireing to the sensors replaced all the plugs on the tranny and at the tps with new ones plz read past post I said that I had already done this but when u are driving it and u lose all the gears includeing reverse has ta be more then just electrical issuses and for the price of the solinoids I got the Allison all adaptors fly wheel and everything for only 300 bucks for that price its worth doing the swap all I am left to get is the drive shaft and a shifter and then I no longer have to worry about the tranny being the weak link to my truck I pull a heavey trail and on an average I have 8 to 10 ton on the trailer and the skid steer on the truck whitch weighs around 1 1/2 ta 2 ton so the Allison is a great upgrade
