Ok quick oil light question
Old May 29, 2007 | 10:09 AM
JWest's Avatar
JWest
Red face Ok quick oil light question
If my truck stalls out or before I start it (when the key is turned to accessory) my oil light is on.
This is normal right? I know it's a noob question and I'm pretty sure it's normal but I just dont like to take chances with an oil light.
My idle is set pretty low and when I was at a redlight today the truck died. I looked down and to my horror the oil light was on and I kinda freaked a little bit.
I guess I worry about too many things when it comes to my truck.
Old May 29, 2007 | 10:15 AM
76supercab2's Avatar
76supercab2
Yes, that's normal
Engine not running = no oil pressure = oil light on.
It also lets you know that the lamp works.
Old May 29, 2007 | 10:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The oil light comes on when you turn the key to on, and it may flicker when idling. The oil sender switch that activates the light is a POS, and leak oil pass the threads, so if the light stays on, that might be the problem. The switch fits most Fords that have an oil light, so finding a new one is as close as your local autoparts store.
B6AZ-9278-B .. Oil Sending Switch-use with light (Motorcraft SW-667)
Old May 29, 2007 | 10:31 AM
JWest's Avatar
JWest
thanks guys. Yeah It's definately working thats for sure!
Old May 29, 2007 | 08:18 PM
Mil1ion's Avatar
Mil1ion
Make sure you actually have the warning light sending unit and not the Gauge sending unit Installed.......and set the idle to spec.
fordnurse
Feb 10, 2012 04:36 AM
oldblue89
15
May 26, 2011 09:32 PM
beanhead6D5
Dec 15, 2009 12:21 AM
ARMORER
Jan 10, 2005 05:38 PM
cgfiend
Oct 15, 2001 11:12 AM
