How do I lower the front end
Old Apr 23, 2012 | 09:23 PM
codafisler's Avatar
codafisler
How would I go about lowering the front of my truck. Not a lot but just enough to give it a meaner stance.
Old Apr 23, 2012 | 09:58 PM
flip4eva83's Avatar
flip4eva83
You can go the expensive route and go air bags, the under $1k option would be drop beams, or the under $300 route would be to cut the coils and get the ibeams cold bent to correct the camber.
Old Apr 23, 2012 | 10:18 PM
HIO Silver's Avatar
HIO Silver
DJM lowering beams are $596 through Summit. Do a rear spring hanger flip for next to nothing except for the cost of some Grade 8 nuts and bolts.
I recall that Fatman Fabrications cane out with an axle flip kit specific for our rigs... bolt-in even.
EDIT: Here's the write-up and a pic...
"Need an easy way to lower the rear axle of your 1965-79 Ford pickup? This newest design by Fatman Fabrications will drop the truck 5” in the back, using the original axle, without any welding being involved. A special bracket allows the axle to be shifted to the top side of the stock rear leaf springs, and a new pair of proper length shocks are bolted to special axle brackets. The frame rail does need to have clearance cut for the “C” in the frame reinforcement plate, which bolts in place to finish the job, providing vertical clearance for the repositioned axle.
Normal weights can still be carried, and this kit won’t weigh down your wallet too much! Check it out with the Fatman tech staff at (704) 545-0369 www.fatmanfab.com"
Mitch1129
33
Jul 2, 2015 09:50 AM
Osiyo59
18
Oct 20, 2014 01:36 PM
craziejoker
Apr 6, 2012 03:03 PM
bigtiny2020
Dec 15, 2009 12:57 AM
jaye
Oct 8, 2007 11:44 AM
