76 2WD Pitman Arm Replacement
Old May 28, 2007 | 03:09 PM
scottlane's Avatar
scottlane
We found the cause of the wandering steering on the 76 and it seems to be a worn out pitman arm. It's real loose and pops at the connection to the drag link. Still can't get it off but we're hoping a soak in some Deep Creep will remedy that.
My question is the replacement pitman arm. I can't seem to be able to find any that are for 2WD w/PS. Everyone that I find is for a 4WD. Are they the same part?
Old May 28, 2007 | 03:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What size truck? F100/150/250/350? If it's an F250 or larger, I need the GVW to tell you what pitman arm you need and the range of years it fits.
You need a Pitman arm puller to remove the arm...and are you sure it's the pitman arm? They rarely wear out...usually it's the ball studs of the draglink that wear out first.
Old May 28, 2007 | 04:21 PM
Mikestrucks's Avatar
Mikestrucks
I have them for the 2WD F100s, F150s, and probably for the F250s as well. So if you do actually have a bad Pitman Arm, let me know and we'll find a match.
But I'm with Bill, never seen one go bad. But seen lots of bad drag link ball studs.
Let me know and I'll help out f I can.
Mike.
Old May 28, 2007 | 07:17 PM
scottlane's Avatar
scottlane
Thanks for the heads up. I just assumed that it was the pitman arm, but like I said I have yet to remove it. Maybe the Deep Creep will have worked by tomorrow.
If it is the drag link ball stud, can they be replaced or do you replace the entire drag link?
Old May 28, 2007 | 07:23 PM
117wb 4sp.'s Avatar
117wb 4sp.
just replace the drag link and get it alignment done. alan
Old May 29, 2007 | 03:41 AM
NumberDummy
Scott..no one can help you till you tell us what model your truck is. F250's have different draglinks than F100/150's. In fact there may be more than one for an F250...so we need the GVW, also if that is what you have. Without the info...digging through the parts catalogs is waste of time.
Old May 29, 2007 | 05:30 AM
scottlane's Avatar
scottlane
It's a 76 F150 Custom LWB. I still need to remove the drag link from the pitman arm to see which part has failed.
Old May 29, 2007 | 06:07 PM
scottlane's Avatar
scottlane
I haven't removed the piece yet but I have had a chance for another look and it is the drag link. I may go ahead and replace the tie rod as well.
Will a pickle fork work in removing the connections?
Old May 29, 2007 | 06:18 PM
partsman01's Avatar
partsman01
I always used pickle forks on most that I took apart, so should work I would think.
Old May 29, 2007 | 06:35 PM
NumberDummy
D2TZ-3590-B .. Pitman Arm ~ Marked: D2TA-3590-AA
D3TZ-3304-B .. Draglink
The draglink is one piece. The other steering rod is actually two pieces (inner & outer) that attach to each other with a threaded sleeve.
D2TZ-3A130-B .. Inner Tie Rod
D3TZ-3A131-A .. Outer Tie Rod
The draglink and tie rod ends fit 1973/79 F100/150
The Pitman Arm fits 1970/79 F100/150.
EDIT: see next post
Old May 29, 2007 | 06:49 PM
NumberDummy
Fyi
The Pitman arm and draglink are obsolete from Ford, but FTE sponsor GREEN SALES has the draglink (D3TZ-3304-B) in stock (but not the Pitman arm). Green Sales is one of the largest obsolete Ford parts stores in the world.
Green Sales is in Cincinnati, Ohio: 800-543-4959
EDIT: also see above ^^^ post
ashleyroachclip
WTB - Parts & other
Aug 18, 2014 06:08 AM
flypfi
Aug 8, 2013 11:03 PM
duback66
Dec 15, 2007 08:15 PM
daveinwestland
May 10, 2006 10:31 AM
