Pitman arm/drag link
Old Dec 15, 2007 | 03:03 PM
duback66's Avatar
duback66
I am changing the 2wd front end on my 92 f150 to a 4wd front end. I can't get the pitman arm off of the power stearing box (broke a puller) so I was going to take the drag ling off at the pitman arm. Anyone know how to separate them? What type of tool do I use? Thanks
Old Dec 15, 2007 | 03:13 PM
danr1's Avatar
danr1
Use the appropriate size separator fork to take the drag ling off at the pitman arm if thats how you want to do it, be careful of the rubber boot when doing so as not to cut or tear it. That can be tough in itself.
I know the pitman arm can be hard to pull off the sector shaft, I've had to use a puller and lots of heat to get mine off to replace the sector shaft seal the last time.
Every time I had to pull a pitman arm off for a new seal, a drop arm for a lift kit or a new steering gear box or what have ya I've regretted it, knowing it was not going to be fun.
Old Dec 15, 2007 | 08:12 PM
dixokai's Avatar
dixokai
A good quality pitman arm puller and a B.F.H. should do the trick.... They can be brutal.
Old Dec 15, 2007 | 08:15 PM
dixokai's Avatar
dixokai
Oh ya, be careful with heat, it does help but you can damage the seal with it.
mdula
Mar 6, 2011 05:26 PM
Kickinbass23
Aug 5, 2010 02:47 PM
BigJake34452
Dec 13, 2009 11:04 PM
LARIAT 85
Jun 17, 2008 12:57 PM
FedFam
May 20, 2004 02:33 PM
