Bronco II Ford Bronco II
Won't Start
Old May 30, 2007 | 07:07 AM
manasota's Avatar
manasota
No gas in the vacuum hose. Distributer is tight.
What controls the firing of the injectors?
Old May 30, 2007 | 08:56 AM
subford's Avatar
subford
There is not a firing pulse for the injectors.
They are wired in banks of three with a power wire that is hot while the ignition is on from the EEC power relay and common to all injectors.
The EEC Computer grounds the other side of each bank to fire three injectors at a time, the banks are (1,2,4) and (3,5,6).
The EEC Computer will ground these banks when it sees a PIP pulse train from the TFI module and the TFI Module gets its information from the pick-up coil (AKA "PIP Sensor", AKA "Hall effect vane switch assembly", AKA "Stator")
So if the injectors are not firing (you can hear them they are very noise, photo below) then you have one of the following things wrong.
Distributor not turning.
Stator in the distributor.
TFI Module.
Wiring and Plugs.
EEC Computer.
The above is taking in to the account that you do have fuel pressure and if you have fuel pressure you have power from the EEC Power Relay.
Old May 30, 2007 | 09:43 AM
manasota's Avatar
manasota
That's some good info. Thanks!
Old May 30, 2007 | 02:39 PM
manasota's Avatar
manasota
OK...I'm not getting anywhere on this. guess it's time to replace some parts and see where that gets me.
Let me summarize:
1. Fuel pressure is about 38-40 lbs. and holds fairly steady. I can hear both pumps engaging when I turn the key.
2. It's getting spark.
3. Spark plugs don't appear wet, just sooty.
4. No sign of gas in any of the vacuum lines.
5. I think I can hear the injectors when I turn the ignition to to the run position, but I can't be certain.
6. No blown fuses, bare or broken wires that I can see.
I'm going to replace the TFI first (about $40).
Old May 30, 2007 | 06:14 PM
subford's Avatar
subford
The engine would have to be cranking to hear the injectors.
Old May 30, 2007 | 07:36 PM
manasota's Avatar
manasota
OK, Thanks.
andrewzx92000
Apr 14, 2011 08:28 PM
Gtboost83
Dec 13, 2010 04:30 PM
ehonda
Aug 8, 2008 04:02 PM
rickthefix
Jul 5, 2008 10:21 PM
mx495
Sep 17, 2007 05:24 PM
