Ok, how do I clean these injectors. Do I need any parts that will need replaced(gaskets, seals etc.)
I rebuild carburetors as a side line, so I got all the dip chems and such to do a proper job, just want to get anything I need before I tear into it.
Thanks much.
BTW truck is 84 f250 4x4 6.9L
How do I add a signature so I don't always have to add what my truck is? Can't seem to figure that one out.
Dielsel injectors are not cleanable other than fuel additives. The injectors work in thousandts of an inch and one spec of dust will ruin them. Best left to a diesel shop to repair if nessarry.
If they can be done by a diesel shop, they can be done by me. Unless they require some special tool that costs lots and can not be fabbed up.
I am one of those guys that will spend five times the amount to do it myself than it would cost to have someone else do it. Nobody touches my rigs but me.
I've done them. Not a hard job. On MB you replace the nozzle and adjust the pressure. What you need is a Injector popper. You put the fuel line on and press down on the handle, the pressure reader will tell you the pressure the injector is popping at. Just remember, a little adjustment goes along way.
Robert
Not afraid of doing them just need some pointers.
Thanks for the advice.
Well said!!
I had to take apart a set of injectors from a diesel ranger once (it was the only way to get them off the engine). I used a three stage cleaning bath and simply took my time, and wouldn't ya know it, the little four banger fired up the first key, fresh rebuild and all.
Pop testers are real easy to make, I have one on my to do list as well.
Easiest set up to make a pop tester is with portable ram hand pump. They are pretty inexpensive to buy, has fill hole and threaded output fittings ready to go, T in a 3000 psi guage an weld a old fuel line into the fitting. ta da- a pop tester.
I found my tip assemblies with 150K miles were worn to the point of not testing, even after ultrasonic cleaning, so I was able to buy new tips fron Diesel Care and performance very reasonably priced. To set up pressure of pop, I found a .002 shim in the spring shim pack raised the pop pressure by 100 psi.
Very close, with the meter I am 8.3* BTDC, timing mark is just 1/2 line advanced. I was just over half line advanced with the by ear method, and had a bit more rattle with cold advance on than I do now. My milage seems to have gone back up again after messing with the glow plug theory, plus the bark is back from my tail pipe.
