I recently slapped on a Mag-Hytec rear cover that alows 6 quarts of 75-140 syn. Why am I getting a grinding now around low speed corners left and right and worse when towing. I have a limited slip rear and added the stock amount of friction modifier, does this indicate I need more to compensate for the added fluid or am I having another problem like u-joint or carrier binding? This is a seat of pants grind that is very nervewracking ,Any help would be great.
do you think that is the noise/ sensation I am getting? I have never felt rear grind before so wasn`t sure that`s what it is.I guess it wouldn`t hurt to kep putting in some additive little by little to see if it goes away, thanks.
In fact, that is the correct way to add friction modifier...a little at a time until the chatter in a turn goes away. I think that is what you are experiencing.
Cgl posted....... Be sure to add 8 oz. of Additive Friction Modifier
KrenzyRyan posted.......4 oz of Ford's XL-3 Friction Modifier
My owners manual says 8 oz per 3.5 qts, but my Mag-Hytec says 4 oz for 3 qts?
I'm not SURE who Neal's avatar represents, but if I had to guess, I'd say it was Kinky Friedman.
Well, Neal?
Pop
Alright Pop, picture yourself in a 1950's tv studio...this guy
and this duck (which came down from the ceiling) are handing you a $50 bill for your correct answer...it is indeed the Kinkster himself...my favorite song, you ask? Why of course... "Get your biscuits in the oven and your buns in the bed".
{((My owners manual says 8 oz per 3.5 qts, but my Mag-Hytec says 4 oz for 3 qts? ))}
This is why I don`t want to put too much more in cause my 6 quarts already got the 8 oz. of modifier. I don`t think I should be grinding this much, I really can feel it on slow turns .
Groucho....Say the secret word and devide an extra hunnerd dollas,its a common word something you`d find around the house, I can still see that stiff George Fennaman standing next to the contestant. How I remember that and not what I had for lunch yesterday I`ll never know.
By the way did Kinky win the election??
My owners manual says 8 oz per 3.5 qts, but my Mag-Hytec says 4 oz for 3 qts? This is why I don`t want to put too much more in cause my 6 quarts already got the 8 oz. of modifier. I don`t think I should be grinding this much, I really can feel it on slow turns .
Check your arithmetic again! The Ford owners manual says "8 oz per 3.5 qts" this is 2.29 oz for each qt of diff fluid! The Mag-Hytec holds 6 qts, so 2.29x6=13.74 oz and you only put in a total of 8 oz for 6 qts, so if you go by the Ford recommendation (they make the diff not Mag) you need to put in 13.74-8=5.74 oz more! Sounds like you need to add another 4 oz bottle and test drive that, and then add another 1/2 bottle if it still has some noise, and then the second 1/2, etc.. if needed!
What kind of diff lube did you use, and what kind of friction modifier?
I got these from Napa ... 6 qts Valvoline syn 75W140 p/n 982
KW Posi-Trac p/n 402508 I`ll get some more and try to add, Thanks
FWIW, I've always used the expensive Ford fluids, syn 75W140, and modifier, C8AZ-19B546-A, and change it every 40K using the Ford amount, and I've had no trouble with 80K miles of actual towing.
