I've ran across some material that would make great body lift spacers. They are hard rubber and 2 1/2" long. I'm pretty sure that I can just buy replacement bolts that are 2 1/2" longer and put them in, but my question is what all will this affect. In other words what other modifications will I have to make?
From: Where they take the census by counting the appliances on the front porch and multiplying by five
Body Lift
You'll need to take into account:
-steering linkages
-shifter linkages
-various hoses (fuel, water)
Maybe some other things. I've never done a body lift. Maybe someone else here has? If you don't get an answer in this forum, go to the big bronco forum. Go back and read a little. I'm sure someone there has done one. Good luck!
That stuff probably will work good. Your steering can most likey just be tilted. Your shifter's need be lengthened. And... remember your radiator goes up with your body, so don't forget to lower it, or the first time you start up your truck your fan cuts the lower hose.
