Aero 4x4, how does it work
Your guess about how it works is pretty much correct. Like Pablo says, the system is always 4wd, but the center differential is open to leave the system in 30/70 f/r drive. When the controller detects a certain amount of speed difference between the front and rear wheels, it will engage an electronic clutch in the center differential to lock it into 50/50 mode. It has some complicated decision algorithm for when and how to engage and dis-engage under what conditions. At worse, you get at least one front and one rear wheel driving, or one front and two rear wheels driving with limited slip rears. This give better driving traction than a 2wd with an open rear differential, which degrades to 1wd in very slippery conditions.
I'd like to take the manually activated clutch idea one step further, by also incorporating remotely lockable hubs in the front. That way, the entire front drivetrain would be inactive until you engage it. I wonder if the front locking hubs of an Explorer can be adapted?
ken
Input torque is applied to the planetary gears by way of a carrier that they are mounted to on journal pins. The differential's outputs are the sun and the internal-tooth gear. Under straight line driving conditions, the entire assembly rotates as one unit at the same speed, just like an axle differential with bevel gears does. But since the one output is larger in diameter then the other, it receives a different amount of torque then the smaller one does because it basically has a longer lever arm then the other one. Remember that torque is force multiplied by distance - the greater the distance, the more torque you get for the same amount of force.
In the case of the Aerostar's planetary differential, the sun gear is coupled to the chain that drives the front driveshaft, and the internal gear drives through to the rear driveshaft. The size difference between the two gears determines what the split of the torque will be - in this case, 1/3 goes to the front and 2/3 goes to the rear. Marketing folks like nice round numbers, so they advertised it as 30/70 instead though. I guess that's easier to print in a brochure then 33.333333.../66.666666...
You could make the argument that by locking the center diff with the clutch (assuming you added a manual switch) so that the differential isn't an issue. The trouble with that is the clutch itself. It's not likely to have been sized for the duty cycle it would see being locked 100% of the time during 2WD operation, with 100% of the torque going across it. I think you'd have durability issues. If the center diff lock was actually a sliding collar/dog clutch, it would be a different story. But that isn't what we've got here.
At the same time, if all of that actually did work, you'd still be turning the front driveshaft regardless of whether or not you had disengagable hubs since you've locked up the center diff. The front driveshaft would be locked to the rear driveshaft, via the manual controlled clutch, and so it would be driven anyway. That means the front diff and axles are also going to be driven as well, so the axles will be turning at the same RPM as the wheels even though the hub is disengaged between them. So, you certainly have not saved anything in terms of drag, and in turn, fuel economy. Seeing as how there's no other real valid reason for disengaging the hubs in an AWD system, there would be no advantage to doing this...
