Will this work?
Old May 27, 2007 | 06:39 PM
kicker1_solo's Avatar
kicker1_solo
Will this work?
My neighbor has a 72 chevy 2wd 1/2 ton rolling frame with complete IFS and rear end that he's trying to give away. Does anyone know if it would be possible to weld that front clip onto my 54 f100? If not, I'll keep lookin' for a camaro front end.
Thanks
Old May 27, 2007 | 07:42 PM
56panelford's Avatar
56panelford
I'm using a 72 c10 frame under my 56 panel and seems to be working out fine but I am still about a few light years from completion. By using the complete frame I had to raise the floor in back about 3 1/2 inches. The truck sitting on the stock chevy suspension will only need to be lowered about 3 inches to just tuck the top of the wheel in the wheel well.
John
Old May 27, 2007 | 08:28 PM
kicker1_solo
Well I thought about using the whole frame but I've already done a little bit of work on my ford frame so I am now just thinking about using the front part. Any info on that?
Old May 28, 2007 | 08:50 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I've seen these front suspensions used under older Chevy pickups but not under a Ford. I don't see why it would not work, however. My reservation in using the truck suspension would be whether or not it would sit low enough (because even under the old Chevy pickups it's still a little high), and it would still basically ride like a truck. I'd keep looking for the Camaro suspension...
Old May 28, 2007 | 07:07 PM
56panelford
As GreatNothWoods mentioned the frame is higher, so your motor will sit higher as well. I had to make a transmission tunnel cover for my panel and lift the cab up by the thickness of a hockey puck. My decision was made by economics at the time that will probably cost me the same either way, hind sight.
John
Old May 28, 2007 | 11:56 PM
kicker1_solo
alright, well thanks for the input guys. I'll hold out for the right parts
SoCalAngler
Jul 14, 2014 09:52 AM
joe_r_dog
2009 - 2014 F150
Jul 5, 2012 12:54 PM
RKCORPS25
Oct 25, 2011 12:23 AM
Carnivore
2004 - 2008 F150
Feb 10, 2009 09:16 PM
milesburns3
Jul 21, 2001 01:39 PM
