fan shrouds
Old May 27, 2007 | 07:54 AM
7702fordboy's Avatar
7702fordboy
fan shrouds
hi all i am intrested in finding a fan shrould for my 77. i had one on the truck before i rebuilt the motor and it got lost/thrown away while i was waiting for the machine shop to do the work. any how i was looking on line and i saw that npd has replacmentm ones but you have to have the fomoco part number witch i dont have. dose any one have a stock fan shrould on a 77 f250 with a 351m/400 4 speed 3 core raditor that could give me the fomoco numbers. any help will be greatly appricated
Old May 27, 2007 | 08:37 AM
whtwolf's Avatar
whtwolf
I got mine from Dinnis Carpenter for a 4 core radiator for $100. The part number was D7TZ-8146-A.
Old May 27, 2007 | 09:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ-8146-A is NOT for a 4 row radiator core, it's the shroud for standard cooling, extra cooling or with air conditioning. The top tank width is between: 2 1/2 / 2 3/4 inches wide.
D7TZ-8146-D is the shroud for the super cooling radiator. The top tank on a super cooling radiator not only has a 3 1/4 / 3 3/4 inch wide top tank, but the radiator core support itself is different, having a wider opening for the super cooling radiator.
Either shroud fits a 351M or a 400 ONLY.
Old May 27, 2007 | 10:07 AM
Broken40's Avatar
Broken40
i would junk yard it for $5 bucks its the same quality but a heck of alot cheaper.
Old May 27, 2007 | 10:32 AM
NumberDummy
Going junkyarding...
Ford fan shrouds have a moulded in ID number at the upper left corner of the shroud. There are 3 shrouds used for 1977/79 351M/400 F100/350's & Bronco's. Here are the ID numbers and what radiator they fit.
D7TA-FA = D7TZ-8146-B = Standard Cooling Radiator
D7TA-AA = D7TZ-8146-A = Standard/Extra Cooling / Air Conditioning Radiator
D7TA-SA = D7TZ-8146-D = Super Cooling Radiator
Old May 27, 2007 | 03:41 PM
IHC120's Avatar
IHC120
Numberdummy,
Would you happen to have a part number for a 77 F350 with a 460,C6 and air. My shroud was missing when I bought the truck.
Thanks, Randy
Old May 27, 2007 | 03:59 PM
NumberDummy
Originally Posted by IHC120
Numberdummy,
Would you happen to have a part number for a 77 F350 with a 460,C6 and air. My shroud was missing when I bought the truck.Thanks, Randy
There's only one for F100/350 and it fits all the 460's 1973/79.
D3TZ-8146-D .. Fan Shroud ~ Marked On Upper Left Corner: D4TA-CA / D4TA-CB
Old May 27, 2007 | 05:02 PM
IHC120's Avatar
IHC120
Thanks very much!
Old May 27, 2007 | 10:03 PM
7702fordboy
number dummy thank you for the info and thanks to everybody i am going find one now and hope it helps some with my cooling problems
Old May 27, 2007 | 11:14 PM
Mil1ion's Avatar
Mil1ion
IHC, Good luck finding one.
Last one I knew of was 3 years ago.
It cost a guy $260.00.
They are very rare.
Rockauto doesn't even list the fan shroud for that model.
http://www.rockauto.com/catalog/x,ca...oling%2BSystem
Old May 28, 2007 | 11:57 AM
IHC120's Avatar
IHC120
National Parts Depot has a large list of fan shrouds, many of which are labeled as "new". One of these new listings is a shroud for the 73-79 F350 with a 460, super-extra cooling and ac with casting numbers D4TA-CA, D4TA-CB. 120.00 each. Also in this listing is the number F-8146-14. Does this look like good bet?
Old May 28, 2007 | 12:23 PM
NumberDummy
I just checked FTE sponsor DIRECTFORDPARTS online parts locater for several 1970's truck fan shrouds, and they have TWO available. DIRECTFORDPARTS offers a DISCOUNT to FTE members. They are listed among the site sponsors at the top of the page..if you don't see it, click on the refresh button till it comes up.
Here are the two fan shrouds available from DIRECTFORDPARTS.
D3TZ-8146-C List Price: $109.63 / FTE member net: $77.49
This shroud fits: 1968/76 360 and 390 engines with standard or extra cooling. It also can be used on 1965/67's. This shroud will not fit the super cooling radiator.
D7TZ-8146-A List Price: $132.22 / FTE member net: $93.45
This shroud fits 1977/79 351M/400 with a standard/extra cooling and A/C radiator. It will not work on the super cooling radiator.
Note: to check parts numbers on Direct's online locator...remove the hyphens from the parts numbers. Type them like this: d3tz8146c or d7tz8146a
DIRECTFORDPARTS IS A FORD DEALER (GAUDIN FORD IN LAS VEGAS, NV). IF YOU CALL, ASK FOR KELLY.
Old May 28, 2007 | 02:43 PM
Jermafenser's Avatar
Jermafenser
Keeping in the theme of this thread for future searches -
Which part number is correct for fan shroud on a 1979 F350 4X4 regular cab, 400 with 4spd and no A/C?
Old May 28, 2007 | 03:29 PM
NumberDummy
D7TZ-8146-A
Old May 28, 2007 | 04:46 PM
Jermafenser
Great info, as usual. Thanks!
