Sponsored by: Kumho
ABS sensor
Old May 25, 2007 | 02:19 PM
wileec's Avatar
wileec
ABS sensor
I beleive that the sensor on the front rt is bad was told that when I had the nuckel changed. ABS light is on at times. When it is off my brakes suck when it is on the ABS is not on and the brakes are old fasioned normal. Went in today to remove the sensor and get a new one, I thought that I could just unbolt it and take it off. NO DICE!!!
Now for the help part...Do I need to remove the disk in order to get the sensor off or is it just stuck and I need to try harder. Did not want to go with the "if it sticks force it. If it breaks it needed replacing anyway." even though it does. I allways seam to break extra stuff.
jimmer2880
Nov 9, 2013 10:44 PM
mikulskn
Jun 26, 2013 11:23 PM
beamundson
1997 - 2003 F150
Mar 28, 2012 04:23 PM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
nashr1
1997 - 2003 F150
Aug 22, 2004 12:08 AM
