General Automotive Discussion
Overiding Pats
Old May 25, 2007 | 12:19 PM
49er_rs's Avatar
49er_rs
Overiding Pats
Torque1st mentioned the paragraph below in a previous thread.
Can someone tell me where I can find the antenna ring he's referring to?
I removed the antenna ring from around the lock and put the PATS key inside the ring secured with zip ties. Then I took the whole antenna ring and secured it with zip ties up under the dash. Now I can use a plain cut key to operate the vehicle. I don't have to have those keys with huge heads on my key ring either. Now I can have a key for all three members of the family and a spare for the wallet for $1.25 each.
Old May 25, 2007 | 12:34 PM
Casey's Avatar
Casey
That looks pretty clear to me. It's around the lock where you put your key in to start the engine.
Old May 25, 2007 | 01:13 PM
73f350sc's Avatar
73f350sc
Maybe you cant find it because you do not have it on your vehicle (which you forgot to describe...model year ect.). Not all Fords were equipped with the PATS system....hence that may not be your problem.
-Chris
Old May 25, 2007 | 01:25 PM
49er_rs's Avatar
49er_rs
Its a 2002 F150 Super Crew Lariat.
Old May 25, 2007 | 04:35 PM
73f350sc's Avatar
73f350sc
Does it have a key with a large rubberized coating and a fancy blue oval...or is it just hard plastic with the Ford logo embossed?
-Chris
Old May 25, 2007 | 04:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
The cover around the column and lock has to be removed to see it. Of course that is IF he has one...
Old May 25, 2007 | 09:37 PM
73f350sc's Avatar
73f350sc
My point exactly...no sense tearing into something looking for an item that may no be there....hence the key question haha. I've read the article on this and it is very well explained...but still it all hinges on the proverbeal 'IF". Hopefully he'll answer back soon and someone can take it from there.
-Chris
DSMMH
Dec 24, 2014 06:21 AM
Gruffid
6.7L Power Stroke Diesel
Jul 11, 2011 07:32 PM
cobrarep
Aug 3, 2008 01:13 PM
murphy
May 24, 2004 08:54 PM
