Correct me if I'm wrong please but last time I saw this brought up it started quite the little argument. As far as I'm aware, you need a special CDL to even haul 2 trailers at once. Either way, Not Recommended.
It really depends on your state. Many states allow pulling two trailers at once with your truck. Most states require that the first trailer be a 5th/gooseneck and the second trailer is a TT. Most states require trailer brakes on the first trailer and some states limit the weight of the second trailer. You just mount a reciever hitch on the rear of the 5th/Goosneck and hook the TT up that way.
Two drawbacks are 1)backing is out of the question so you have to plan ahead, 2) you have to weigh everything carefully to make sure you are not overloaded and that the weight is distributed properly. Same rules apply for pin(15-25%) and tongue(10-15%) weights.
I just looked up Georgia and triple towing is not allowed. Triple towing is also not allowed in CA, OR, WA, but it is allowed in ID, UT, WY, MT, AZ.
In Minnesota triple towing is allowed but the 1st trailer must be a fifth wheel no longer than 28' and the 2nd trailer must be a boat, atv or Motorcycle with the total length not to exceed 60'. Also triple towing is not allowed in the seven county area during the hours of 6 to 9am and 4 to 7pm.
Many 5ers have less pin weight than that - mine was designed with more like 5% pin weight. Triple towing with a set up like that could quickly go to negative tongue weight over bumps as the tongue of the last trailer loads the rear of the 5er...
This is 2 trailers. It is called DOUBLES towing. It is allowed in most states. Some, including CA require a CDL with doubles rider. I towed doubles last weekend in SoCal. 5th, and a PWC behind. Total 11k and 55 ft. No problems.
55ft would be a dream, I'm spread out 73'. ND law says I can go to 75' but hopefully the next camper will be a fifthwheel so even if I do buy a larger boat I surely won't be any longer than I already am!
The whole key to doing this is first to abide by your state laws, next is to set up the whole train with proper hitches, sway bars, tongue weights, mirrors/cameras and then remember exactly what your towing when your manuvering down the road; IE don't try breaking any land speed records and keep your manuvering and lane changes smooth! with the proper setup and a comperhensive driver it can be a great way to get a whole lot of stuff from point A to point B and doesn't need to be eventfull!
any one ever tow a fith wheel and a small boat like a bass tracker? What hitch did you use and how well did it work? I will not be towing far or fast.
I double tow all time (One truck one 5ver and one boat trailer is double tow) I have a receiver hitch on the back of my trailer made by Hitchhiker for HH trailers. With proper planning it works just fine but backing up is a problem just don't backup (proper planning). In my gallery I have a photo of the rig.
In Michigan, it's called a "recreational double" and it requires a knowlwdge test and a free "R" endorsement. No skills test is required.
'A "recreational double" is a pickup truck pulling a fifth-wheel trailer designed for recreational living purposes, with a second trailer attached to the rear of the fifth-wheel trailer ... The total length of the combination cannot exceed 65 feet'
I was under the impression that as long as the rv was a fith wheel it was legal in Ga. I thought I found it in writing at one time but i cant find it to save my life.
You will find that a lot of states allow it with a 5ver but not with a TT, at one time the Tailer Life Towing guide had them listed separately but they dropped that about the same time they mistakenly started calling it triple towing.
I see a lot of RV sites have a guide with towing requirements and they all show Ga as a no triple towing state but as I stated above I thought w/ a fith wheel it was ok. I guess I may have to call the DMV, but you know how it is when you call the government. If anyone knows where to find the info I would appreciate.
It is NOT legal in GA under any circumstances. Even a snowbird going to FL for the winter is illegal, but I've seen it on the road many times. I checked with the GDOT and they said only a TT style dolly and a second kingpin trailer would make it legal. You would also need a CDL with doubles rating.
