Overdrive
Old May 24, 2007 | 03:15 PM
buddypicasso's Avatar
buddypicasso
Overdrive
This is probably a dumb question but here goes:
On a 2005 Ford F150 does it matter what speed you are going when you push the button to either shift into or out of overdrive?
Thanks!
Old May 24, 2007 | 05:01 PM
Dustin1690's Avatar
Dustin1690
Not not really the speed dont matter at all or i at least i dont think so and no question is a dumb one man ask away
Old May 24, 2007 | 06:12 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
no. You can be going 99 mph and push the button. The only thing that will happen is that your engine will rev up to a higher RPM and it really isn't a good thing to do alot. You shouldn't even come close to the Rev limit though.
your O/D doesn't even get used until your going 40+mph though. So there is no real reason to disable it unless towing or to engine brake when going down a steep hill.
Old May 24, 2007 | 08:25 PM
buddypicasso
Overdrive
That is exactly what I was wondering about. Towing our trailer at 65 mph and turning the overdrive off when I find myself going down a long hill and want some engine braking so I don't wear out my brakes or overheat the brake fluid.
Old May 24, 2007 | 08:34 PM
90Ford250's Avatar
90Ford250
keep overdrive off when towing. the extra drag on the engine will cause it to keep down shifting . that means your transmission is going to heat up . not good.
Old May 25, 2007 | 01:10 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
for long downhill towing you should turn O/D off. it will help keep your brakes cooler and the engine braking won't hurt the motor or the transmission
you only need to turn O/D off during normal towing if you see the transmission downshifting to 3rd. I personally leave it in O/D on flat ground and lock it out when I get into hills that cause it to downshift.
Old Jun 1, 2007 | 10:01 AM
Steve_Uzi's Avatar
Steve_Uzi
I NEVER tow in Overdrive... even if it is only a 400 lb trailer with my nephews 600lb quad.... I am an old school 3 speed slush boxer... so I have no problem using my current truck as a 3 speeder slushy
Prozon
Offroad & 4x4
Aug 12, 2008 10:35 PM
1stF250
May 25, 2008 09:42 AM
donybrk
2004 - 2008 F150
58
Jun 27, 2007 03:32 PM
MRStace84
May 11, 2007 01:21 PM
pwitort
Aug 28, 2003 09:25 AM
