S & B Intake
"IAT1 (Intake Air Temperature #1)
• The Intake Air Temperature1 (IAT1) sensor is a two wire thermistor sensor that is located inside the Mass Air Flow (MAF) sensor
• The PCM supplies a 5 volt reference signal which the IAT1 uses to produce an analog voltage that indicates the intake air temperature.
• The IAT1 sensor’s primary function is to measure intake air temperature to control the timing and fuel rate when cold starting. The continuous monitoring by the IAT1 sensor limits smoke emissions.
• The MAF/IAT1 sensor is mounted in the intake air piping after the air filter.
IAT2 (Intake Air Temperature #2)
• The primary function of the IAT2 sensor is to provide a feedback signal to the PCM indicating manifold air temperature.
• The PCM supplies a 5 volt reference signal which the IAT2 sensor uses to produce an analog voltage that indicates temperature.
• The PCM monitors the IAT2 signal to determine if the temperature is
satisfactory.
• During engine operation, if the PCM recognizes that the IAT2 signal is lower or higher than the expected value it will set a Diagnostic Trouble Code (DTC) and illuminate the amber malfunction indicator lamp on the dash.
• The IAT2 sensor is a two (2) wire thermistor type sensor.
• The IAT2 sensor changes resistance when exposed to different air temperature.
• When temperature decreases, the resistance of the thermistor increases. This causes the signal voltage to increase.
• When the temperature increases, the resistance of the thermistor decreases. This causes the signal voltage to decrease."
It appears the two sensors readings are to far apart from what the computer is expecting to see, this is causing the CEL and code P0113. This is going to effect the engine timing and fueling parameters.
Check to make sure there are no broken or disconnected wires or that one of the wires is not shorted to power. If all of these check out okay, then the problem is do to the fact that the temprature differential between IAT #1 & #2 is beyond the expected parameters of the engine.
The second scenario is directly related to the A/M intake, and the only way to correct this and leave the A/M intake installed is to get a Custom tuner (SCT XcalII with custom tunes) and have the program parameters of the IAT differential changed.
If the PCM is seeing to high of a voltage reading from one of the IAT sensors it is going to alter the timing and fueling strategies of the engine to compensate for this. This could result in decreased power and performance.
As far as open air boxes and the 6.0 PSD, at least on FTE very few people run A/M intakes and fewer still the open style.
Thanks also to mrxlh and I will seriously take your suggestion under consideration.
Well if you have read all the threads on A/M air intakes then you already know the answer is they are not needed until you reach 500+ Hp (this takes more than a tuner). The factory OEM filters flow more air than the stock or mildly modified 6.0 can use.
If you read the posts on tuners & chips, you will find that the Diablo tuner is iffy for the 6.0 and your best bet is the SCT XcalII with custom tunes form either Matt at LIPD or Eric at Innovative.
So you may want to re-think your tuner choice.
To answer your question directly, use Stock OEM intake, MBRP exhaust and preferrably SCT XcalII with custom tunes.
Good luck
The tuner you are purchasing from extreme diesel or any off the shelf SCT XcalII dealer only comes with the SCT one size fits all canned tunes. These are a compremise at best, just like the OEM tune from Ford. The important part is to get the SCT XcalII with "custom tunes" written specifically for your truck and driving style. This will not only optimize performance of your engine but your transmission as well.
If you buy an off the shelf tuner from Xtreme diesel or anyone else, you will then have to pay a custom tuner to write custom tunes for your truck if you want tunes tailored just for your needs.
By going with the canned SCT tunes you are giving up one of the biggest benefits of the SCT XcalII and that is the custom tunes.
Call Matt at LIPD or Eric and Innovative and talk to them. Then order your SCT XcalII from one of the two of them with custom tunes written specifically for your truck.
www.lidiesel.com
http://ophion.site5.com/~dieselta/store/
The $70 you save running canned SCT tunes will not come close to the damage you may potentially run into by not running custom tunes written specifically for your truck, load and driving style.
Hope this helps
