power stroke dies
Old May 22, 2007 | 02:25 PM
toreed47's Avatar
toreed47
power stroke dies
1996 f250 4x4 7.3 power stroke going down the road and it cuts out two or three times and quits the check engine light , the battery light and the wait to start light flash on and off. The IDM relay clicks on and off also. Sometimes you can turn the key off and back on and it will start and sometimes it takes a while but has not failed to start yet. It might run a week before it does it again. any idea what the problem is?
Old May 22, 2007 | 02:30 PM
rockyrider's Avatar
rockyrider
Sounds like CPS (Cam Position Sensor) to me. Search this site for more info on how to change and where to buy.
Old May 22, 2007 | 02:31 PM
powerstroked162's Avatar
powerstroked162
have you had to replace your CPS yet? It sounds CPS related to me.
Cowboy Steve
Old May 22, 2007 | 03:46 PM
tjbeggs's Avatar
tjbeggs
I vote CPS also. If not its worth it to have a spare for when it DOES go out.
Old May 22, 2007 | 03:53 PM
Neal 97 250's Avatar
Neal 97 250
They have certainly gotten much cheaper. It is a cheap way to isolate alot of probs. I always carry a spare now.
Old May 22, 2007 | 03:56 PM
powerstroked162
What was that part number Tj for the new CPS? I need to go get a spare
Cowboy Steve
Old May 22, 2007 | 04:06 PM
tjbeggs's Avatar
tjbeggs
F7TZ-12K073-B
link:
http://catalog.powerstrokeshop.com/p...catalogid=3660
toreed47 even though this sensor says it only for 97+ trucks you can use it on your 96. it is much cheaper than the ones out there for the 96 and under trucks. Like $125 cheaper from the dealer! and it still less then half price of the ones floating around ebay.
Old May 22, 2007 | 04:07 PM
toreed47's Avatar
toreed47
I'm going to get a cps sensior today and try it will let you know if thats it.
Old May 22, 2007 | 04:09 PM
powerstroked162
Thanks Tim!
Cowboy Steve
Old May 24, 2007 | 03:45 PM
toreed47's Avatar
toreed47
replaced the cps so far so good hope that take care of the problem thanks for the help.
Old May 24, 2007 | 04:00 PM
tjbeggs's Avatar
tjbeggs
good to hear! happy to help!
Old Jun 4, 2007 | 07:28 PM
toreed47's Avatar
toreed47
back again same problem I hope the cps last more than 2 or 3 hundred miles. Doing the same as before what I can't under stand is why the battery light and wait to start light blink on and off when this happens.
Old Jun 4, 2007 | 08:30 PM
Neal 97 250
If the engine does not completely die I would check the Throttle Position Sensor. I have had a similiar problem while driving down the road and I tap on the acelerato a few times while still rolling and it picks up. All the lights come on as well. Just a thought not sure if this is your problem but doesn't help to check. I unplugged it and checked the connections and replugged it and wiggled it to be sure it has a good contact and it hasn't done it in a while. Hope it helps.
Old Jun 4, 2007 | 10:08 PM
bigbadwolfe's Avatar
bigbadwolfe
you can also try to clean the tps with wd-40 i have read about the guys here doing this with a good outcome
Old Jun 4, 2007 | 10:19 PM
Neal 97 250
True BBW I didn't do that but I have heard of good results as well.
