AE 5.2 Posted
http://autoenginuity.com/downloads.shtml
Craig
AutoEnginuity OBD-II ScanTool Release Notes
(C) Copyright 2003 - 2007
Release Notes:
The 5.2 adds Jaguar factory-level coverage to our enhanced European line-up. Coverage will include sensors, bi-directional controls, system tests, and trouble code retrieval and clearing for 1995 – 2007 models on body, chassis, engine, and transmission controllers. 5.2 also is our first installment of our enhanced Chrysler and GM improvements. Finally, Ford PATS programming is now complete for '96 - '06 vehicles and Powerstroke 6.4L has been introduced.
05/08/2007 5.2 Release:
• Added Dodge Sprinter to the vehicle list
• Added Porsche Cayman and Volkswagen Polo support
• Added warning for all controllers that require a special adaptor cable to be inlined to be checked when a connection was failed to be established
• Improved the data logging file parsing by increasing the size of the internal buffers so large sensor lists can be processed
• Improved the Spanish and German User Guide for the 5.x release
• Improved the Pocket PCs BlueTooth support of enhanced interfaces (BMW, Land Rover, and Jaguar) that were long response protocols and didn't work with previous versions
• Fixed AE Enhanced connector not being tested for after the first pass through the ports
• Fixed compatibility issue with USB hardware not working with a PC Wireless product
• Fix Pocket PC debugging logging file not being created (//My Documents//AutoEnginuity ScanTool.log)
• Fix Pocket PC BlueTooth connection failing to connect after a Disconnect then Connect attempt
• Fix Pocket PC clipping the VIN on the right-hand side of the display
BMW
• Added DME S54/S62 Electrical Fan Speed 50% and 90%
• Added MS42.1 and MS41.1 smooth running PIDs support
• Added MK60 ABS Bleed support (E46 non-M cars)
• Fixed MK60 bi-directional controls bug with Inlet Values
• Fixed DME MS42.1 DTC retrieval showing a false 00 FC code
• Fixed LCMIII trouble code clearing not working
• Fixed X5 4.6iS DME connection issues
Chrysler
• Added 2000 Chrysler Voyager and Grand Voyager to the list
• Added Transmission Quick Learn for NGC based transmissions
• Added Governor Pressure for JTEC vehicles
• Added the ME2.8 Engine Module support (Crossfire '04-'06)
• Added the EDC16C2 Engine Module support, Other systems all ready supported for (Jeep Liberty Diesel '05-'06)
• Added the CR2 and CR3 Engine Support (Sprinter '04-'06)
• Added the SIM-70 Engine controller for the Neon and PT Cruiser 1.6 Liter engine ('01-'05)
• Added 2.7L entry for the '01 Dodge Intrepid
• Added SBEC/JTEC System Tests:
Erase All DTC Fault Codes
Reset All Adaptive Memory Fuel Cells
Reset All Non-Volatile Memory
Reset CAM and Crank Misalignment
Reset CAM, Crank, and Sync Status Record
Reset Duty Cycle Monitor
Reset Engine Running Time Record
Reset Fuel Shut-off Record
Reset Intake Airflow Control Stepper Motor Position
Reset Trip Information
Set Minimum Throttle Position to Maximum
For NGC modules added reporting of:
Part Number
Reflash Program Counter
• Added warning message if system is CCD to warn that it is not supported at this time
• Changed showing of all the actuations available on a SBEC or JTEC module. Now only available actuations based on the engine size are shown
• Improved sensor auto detection speed by culling sensors known not supported on models
• Improved correct protocol selection algorithms
• Fixed freeze frame sensor for Fuel Level having decimal place
• Fixed generic powertrain from operating with enhanced option enabled
• Fixed AE Enhanced communications failure with some NGC controllers (Requires firmware 5 update)
• Fixed NGC-based actuations Set Idle speed, Actuate Fuel Injector, and Fuel Pump Relay not working
Ford
• Added Powerstroke '08 enhacned coverage support
• Added all missing PATS key programming for '96 - '06 (works with all variations now)
• Fixed Crown Victoria '98 and '99 having the incorrect ABS controllers in the system supported list
• Improved High and Low Speed Fan Control on vehicles that report Not Supported yet will still work
Jaguar
• Added all enhanced systems sensor, trouble code, and actuation support for SType, XJ, XK, and XType '95-'07
• Added System Tests:
Brake Sensor Setup
Display Last Alarm Activations (SLM and GEM)
Display Fuel Adaptation Tables
Fuel Adaptation Monitor
Electronic Parking Brake Release To Service
Front And/Or Rear Light Calibration (ADHLS and HCM)
Reset TCM Adaptations
Yaw and Lateral Accelerometer Calibration
Reset ABS Configurations
System Self Test (SType Only GEM, REM, DDM, PDM)
EVAP Leak Test
• Added all '07 DTC descriptions
• Improved Mode 6 support
GM
• Added 2004 Pontiac Bonneville Product Line H engine support
• Added the EVAP Vent Solenoid Bitmap for 2003 LT 4.3 and 4.8 Liter
• Added 5 bitmaps for '00 (K) LT Body Control Module, no missing sensors
• Added ABS Systems for (C) - '98-'00 and '02-'05, (K) - '98-'99, (W) Oldsmobile - '98-'02 and '04, (W) Chevrolet - '00, (G) - '01-'03 Passenger
• Added 3.5 Liter for the Uplander
• Added 'ATC' addition to the transmission types that are associated with Automatic Transfer Case
• Fixed HeartBeat being enabled from affecting some GM controllers
• Fixed door lock actuation for '99-'02 J Body BCM controller
• Fixed issue with missing transmission on some vehicles (e.g. Chrysler '99 Blazer)
• Fixed the EVAP Vent control for all Yukon 5.3L
• Fixed the Body actuation list for Light truck's from '96-'06
Mazda
• Fixed 626 '02 enhanced coverage missing from the vehicle selection list
</TD></TR></TBODY></TABLE>
