How to manually flush/drain C6
Old May 21, 2007 | 09:27 PM
apropos's Avatar
apropos
Got a '89 C6 tranny -- want to know how the DYI way for tranny flush, or at least draining several quarts at a time.
'How do I drain the torque converter?
Do I need to replace the gasket?
What's a good place to get the filter?
Old May 22, 2007 | 06:50 AM
stuart1's Avatar
stuart1
Remove the pan and drain it.
The filter is really a screen and unless it's ripped does not need replacement.
Now is a good time to install a drain plug in the pan.
Remove the inspection cover between the engine and transmission.
Turn the convertor until you see a 7/16 plug.
Remove this and allow the convertor to drain.
This can be done with a 15/16" deep socket and ratchet on the front pulley.
Once the drain plug is positioned remove the ratchet and socket.
Pull the vacuum line off the modulator and see if any fluid is present.
If there is replace the modulator.
It is wise to replace the pan gasket.
Do not use any glue.
After you have it back together pour 6 quarts of fluid into it and start the engine.
Some recommend less but this transmission will hold up to 8 quarts without puking out the breather port.
Add fluid until it is just below the full mark.
Move the lever into each gear position and recheck the fluid level.
Old May 22, 2007 | 06:54 AM
cujo8's Avatar
cujo8
To drain the tranny you need to drop the tranny pan and you should always replace the gasket when doing this. Make sure you thoroughly clean all the old gasket material and oil off the mating surfaces and make sure the pan mounting surface is flat. You need to carefully torque the pan down in at least 2 stages and do not over tighten the bolts or you could end up with a leak.
To drain the converter you need to remove the transmission inspection plate and you also may need to remove the starter to remove the inspection plate. The torque convertor has a drain plug and if you can't see it, you'll have to rotate the flexplate/convertor until you have the drain hole on the bottom. I use a wrench onto one of the convertor to flex-plate bolts to rotate the convertor. Then just remove the plug and let it drain. This is usually as far as I go for a draining the tranny fluid, but you can also disconnect the tranny lines from the transmission and then use compressed air to flush out the radiator if you want. After everything is all button back up, you can add three quarts of fluid through the tranny dipstick hole and then start up the truck and continue to add the appropriate amount of fluid for your tranny.
SEH43
Jun 23, 2013 01:45 PM
genscripter
Feb 6, 2013 04:18 PM
Rancho*Ryda
Feb 13, 2010 10:32 AM
gbeach
16
Jan 12, 2004 07:57 AM
orangeford
Jan 29, 2003 07:26 PM
