Sponsored by: Real Truck
2004 F250 conversions
Old May 24, 2007 | 09:32 AM
ramblincowboy's Avatar
ramblincowboy
If you want all OEM parts, you'll need an axle and a bed from an F350 drw. If I were doing it, I'd just use the aftermarket conversion kit - I don't think there's a huge difference in the weight rating of your axle and that of an F350, and you'll still get the stability and the look. If you're going to just add the flares to your existing bed, I think you're going to need to cut out your current fender opening for clearance (look at a factory dualie bed, they're open all the way up to the flare). The narrower drw axles are from cab and chassis models - if you want to use those on a factory bed, you'd have to extend the fenderwheels farther toward the beds center, and I'm not real sure they'd even work with your frame anyway.
Do a search in this forum to find grill/headlight conversions - I think several posters here have updated that, and I'm pretty sure there are aftermarket kits available.
The climate control thing sounds like more trouble than it'd be worth to me, but if you get it done keep us posted - I'm sure lots of folks here would be interested.
Good luck.
David
Old May 24, 2007 | 10:03 AM
rbaker6336's Avatar
rbaker6336
if memory serves me right 350 has a longer wheelbase(the older ons did) but flares may cover it
Old May 24, 2007 | 08:13 PM
M1platoon's Avatar
M1platoon
The model im looking at getting is a 2004 F250 Supercab longbed. i want it looking like a true ford Dually. As for the wheels I realy want the 2006 Alcoa clasics. not sure if these are factory rims or if i can just buy them fro Alcoa them selvs?
Old May 24, 2007 | 08:56 PM
roughrider46's Avatar
roughrider46
I have a 2003 f350 dually the rear axle is 1/2 inch longer then the front if you take the 4 " spacers off the front. I'm converting to single wheel so if you need spacers and aluminum dually wheels let me know it isall coming off. you can keep your axle it will be fine . ? et me know i will swap you wheels and show you how put the spacers on could be done in a half day.
Old May 24, 2007 | 09:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, actually there is a huge difference between the rear axle load ratings of the F-250 SRW (and F-350 SRW) and the F-350 DRW. Like, 2000 pounds different.
klmracing
Vehicles for Sale
May 6, 2015 06:22 PM
tsmithr419
Dec 22, 2014 01:48 AM
Charlotte1
Aug 27, 2014 11:41 AM
Bearlb67
Nov 1, 2013 11:53 AM
arcturner
Jun 24, 2004 05:42 PM
