Sponsored by: Real Truck
Lockup Torque converter
Old May 2, 2007 | 05:39 PM
Russ G.'s Avatar
Russ G.
Hi All. I have a 97 F-250 diesel.When on the throttle pretty hard at around 43 mph the torque converter locks up very violently!!! I had read that the computer looks for a 100 rpm or so difference, But this goes from about 2500 to 1500 rpm!! No trouble codes!! This is after the trans goes into third gear. IF I am on the throttle easy just feels like another shift of the trans. I don’t believe the converter is broken as it will spin the rear tires if I stand on it. Any ideas??<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
If I let off the throttle at this speed the converter locks up normal and then I can get back on the throttle.<o></o>
Thanks Russ<o></o>
<o> </o>
Old May 24, 2007 | 08:19 PM
amish77's Avatar
amish77
I had a taurus with the same problem, especially if I was going around a bend. felt like I was getting rammed by another car. Never did figure it out though.
Old May 24, 2007 | 09:46 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hi Russ. Welcome to FTE!
A 2500 RPM to 1500 RPM drop isn't a locking converter, unless the converter is slipping a bunch. It sounds like something else is wrong with your transmission.
