General Automotive Discussion
Distributor question
Old May 21, 2007 | 12:11 AM
385seriesHemi's Avatar
385seriesHemi
Question Distributor question
Ok here what happened, its a HEI Gm small block distributor and last weekend it wouldnt let the engine go over 3000rpm at the race track. My question is what in the distributor would not allow the engine to go over 3000rpm???? I have been thinking but nothings come to mind yet. I hate the feeling of not knowing what is wrong with it so thats why I am askin' here.
Old May 21, 2007 | 12:36 AM
Mil1ion's Avatar
Mil1ion
What was the timing value at 3000 rpm ?
Old May 21, 2007 | 11:01 AM
385seriesHemi
That I wouldnt know, we just swapped one from my old nova small block. Im sorry i dont know the timing value you are looking for, we were more concerned about gettin our engine n trans back in the car b4 the race yesterday. Would you have any idea of what internal distibutor part it could be though??
Old May 21, 2007 | 01:12 PM
Mil1ion's Avatar
Mil1ion
Centrifigal Advance Weights or Heavy duty springs on them.
If the distributor allowed for say ...35-50* advance then that won't be the rev limiter.
Had you put a timing light on it at that RPM you could verify the degrees of advance.
Old May 21, 2007 | 01:34 PM
385seriesHemi
Ok, well thanks for the input man, now I know what can be the calprit for this stuff if it happens again. This was the first time I had ever ran into it so I wasnt sure what to do when it happened. - My other question is who does this happen to more Gm-Ford-Chrysler? or is it just a thing that happens when every distributor gets to a point of in need of rebuilding?
Old May 23, 2007 | 02:28 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
It could be the coil or the module.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
<O
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old May 23, 2007 | 03:25 PM
385seriesHemi
Thanks for the info on your product, I wont be getting a new one for the race car, but a guy mentioned your distributor for the 460 stroker im buidling for my Nova. As for the rest of the system I was thinkin MSD, - its gona be 520 cubes - cam is gona have a .542/ .552 lift on it and I have a Weiand Stealth intake manifold I dont kno the compression yet tho. what would you recommend for the engine I am building Mr sponsor? Do you guys just make the distributors? or do you also make a HiPo ignition systems also?
Old May 29, 2007 | 03:10 PM
PerfDistIgnition
FTE Sponsor
[QUOTE=385seriesHemi]Thanks for the info on your product, I wont be getting a new one for the race car, but a guy mentioned your distributor for the 460 stroker im buidling for my Nova. As for the rest of the system I was thinkin MSD, - its gona be 520 cubes - cam is gona have a .542/ .552 lift on it and I have a Weiand Stealth intake manifold I dont kno the compression yet tho. what would you recommend for the engine I am building Mr sponsor? Do you guys just make the distributors? or do you also make a HiPo ignition systems also?[/QUOT
We offer high performance street distributors AND all-out racing distributors.
Our Street/Strip D.U.I.(or Duraspark) will be a good choice for your 460 stroker.
http://www.performancedistributors.c...stributors.htm
We will calibrate your advance curve on a distributor machine based on your cam, cubic inches, compression ratio and octane of your gas.
__________________
FTE Sponsor
20xrd
Bronco II
Mar 2, 2014 08:10 PM
cdawley4
15
Oct 14, 2010 11:10 PM
LARIAT 85
May 11, 2009 01:48 PM
XtremExcursion01
Jan 3, 2009 05:01 PM
