Ford Service / repair DVD
The genuine Ford DVDs are chock full of information, they have everything in them just as fl1a described, along with some TSBs and Recall info. However many of the of the DVDs covering the newer vheicles "expire" after a certain amount of time. As a workaround, you change the date on your computer. Which means you have to remember to change the date, both before and after using the DVD, each and every time. If you don't mind doing that, then it ought to work just fine for you.
westriver87
05-17-2015 10:07 PM
fran m
11-28-2005 06:54 AM
