Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Deca Welder
Old May 20, 2007 | 08:54 PM
furball69's Avatar
furball69
Deca Welder
I have to say I was skeptical about buying a welder at Princess Auto but when I saw that these welders were made in Italy and further research showed that the Deca Welders are sold in the US under the Ryobi name, I thought what the heck. Picked up a 130 AC, wire feed 'no gas' welder today and am pretty impressed with it, so far.
I welded up some 1/8" metal on the "Low" setting and I think it works excellent. Lots of spatter, like a 6011 electrode but other than that, I like it.
I wonder if this thing can be 'converted' to an arc welder, or if there are different varieties of flux core wire for nicer welds?
Old May 20, 2007 | 10:52 PM
bhardy501's Avatar
bhardy501
I dont know any thing about flux core wire but is there an upgrade available to add sheilding gas to make it a MIG welder instead of a straight flux wire welder?
Old May 20, 2007 | 11:51 PM
furball69's Avatar
furball69
Yes, the 150E model is mig capable and from what I could tell at PA, it's only about 30 dollars more.
Old May 21, 2007 | 06:47 AM
bhardy501's Avatar
bhardy501
The MIG options might cut down on the splatter some.
Old May 21, 2007 | 11:28 AM
furball69's Avatar
furball69
I wasn't really interested in the MIG option because I don't want to be fussing about with the extra space needed for a bottle etc. when I can use the 400 volt mig at work if I really need to.
I took the side panel off my unit and I don't see any reason why I can't hook up a cable and clamp to run it as an arc/SMAW welder, which would be sweet, as that's what I learned on and 7018AC electrodes make clean strong welds.
Incidentally, I found a link to plans to build your own 130 amp TIG welder for about $300.00... http://classicbroncos.com/homemade-welder.shtml
Old May 21, 2007 | 07:30 PM
Ford_Six's Avatar
Ford_Six
The control system for MIG and stick are totally different- MIG is constant voltage, whereas stick and TIG are constant amperage.
Old May 21, 2007 | 08:27 PM
furball69's Avatar
furball69
Yeah, I was doing some more reading and the OCV probably isn't high enough anyway... oh well, I'll jsut get a little grinder and some flap wheels to clean stuff up if needed.
Old Mar 6, 2008 | 10:48 PM
Eagle460's Avatar
Eagle460
I have the Deca 180E mig welder from princess auto. Got it on sale for $550, regular almost $800. Works excellent. I have alot of contol over heat and wire feed, and I have the option of running gas as well. Seems like a quality budget welder to me.
EDIT: Didn't realise the age of this thread. oops.
4x4slik
Garage & Workshop
Aug 4, 2017 05:35 PM
foofees
18
Aug 8, 2016 07:59 AM
kyle j
33
May 11, 2016 05:57 PM
blk450er
Feb 29, 2016 03:33 PM
54Guy
Garage & Workshop
78
Oct 29, 2015 12:47 AM
