1978 - 1996 Big Bronco
Bronco running hot
Old May 18, 2000 | 12:20 PM
fordzgal's Avatar
fordzgal
Bronco running hot
Hey I am not a "mechanic" in anyway but with direction I can get it done...where to start? My Oil gage says High and it is squeling but it has oil....is the squeal a belt?
Old May 19, 2000 | 06:22 PM
AlM's Avatar
AlM
Bronco running hot
yo,
What year and engine in that Bronco? My 78 351M runs @ 60 psi when on fast idle, then drops to around 30 after warming up.
I hope it's a belt, which can be checked: With engine off, see how much tension is in the belt (s)..usual deflection is a 1/2 inch or less on the longest straight length of the belt (s). And if you can turn the alternator fan by hand, then that belt is too loose.
or run the engine nd use a 2 0r 3 foot piece of garden hose or a long cardboard tube, like from gift wrap.
Use the hose (or a stethoscope if you have a nurse or doc pal that doesn't mind it getting dirty..lol) and see if you can locate the squealing.
good luck,
Al
Old May 19, 2000 | 11:17 PM
fordzgal's Avatar
fordzgal
Bronco running hot
My Bronco is an 83 with a 350w...which I plan to drop kick it. It is so gutless, I want to pull a horse trailer but the poor thing can barely pull itself up a hill let alone a trailer!
Old May 20, 2000 | 04:10 AM
AlM's Avatar
AlM
Bronco running hot
go for it..a 460? check out others here who have done this swap. or try this other big late model Bronco discussion site: http://dosxxs.off-road.com/wwwthreads//wwwthreads.pl?action=list&Cat=&Board=offroadfordbr oncolate
good luck!
Old May 25, 2000 | 02:38 PM
RRL78's Avatar
RRL78
Bronco running hot
matowns21
19
Dec 30, 2011 09:27 AM
powerman01
Jan 23, 2009 04:08 PM
Adam0331
40
Aug 31, 2008 09:09 AM
rmcmillion2006
Dec 12, 2007 11:42 PM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
