Front Reciever
Old May 18, 2007 | 10:45 PM
mudslingur's Avatar
mudslingur
Front Reciever
My brother in law gave me a Champion 10000 pound winch thats mounted on a 2inch reciver mount.has anybody made a 2 inch front reciever.I was going to copy one that a company makes,but these ol truck frames are way differt from this boxed frame chit that there is now days.
thanks
Old May 18, 2007 | 10:53 PM
75F350's Avatar
75F350
I made one for my '74. It was off of a 97-03 F-150. It had the proper bend to it to fit the front end perfectly. I had to cut the ends off, and turned it upside down, but it attached between the framerails, and exits right in the center of the front license plate. After I cut a square hole in the bumper, the reciever barely sticks out. It is actually just flush with the factory bumper. I made a frame with a 2" square tube mount, so I can still run a front plate on the street. It fits pretty good. I have the option of using a hitch to move the trailer around, or sticking the shackle mount in it, or the winch mount.
Old May 19, 2007 | 01:06 PM
George Frasier's Avatar
George Frasier
The front reciever is great for pushing a boat trailer down a ramp to unload/load it, speshully if the ramp is crowded.
Old May 19, 2007 | 02:38 PM
Hyperactive460's Avatar
Hyperactive460
i also made one for my 78 f-250. my cousin was junking an old truck so i cut off the hitch and then made it to fit the front of mine. i'll get some pics of it once installed on the frame.
Old May 19, 2007 | 03:53 PM
uriah's Avatar
uriah
One of my old F250s had a homemade hitch up front somebody made to launch a boat. Made out of waterpipe, with the hitch sticking out about 8". After I put a dent in my shin (which I STILL have...) I cut it off with a grinder.
Old May 20, 2007 | 01:09 AM
Ford400Man's Avatar
Ford400Man
I am about ready to do the same to my truck. One difference though;
I am going to get a 1/4 inch slab of metal, about 6 inches wide and bolt/weld to the frame just behind the front bumper, then put on a Reese bumper mount receiver on to that. Should be plenty strong for a winch or a shackle. Cheap, and quick!! But effective!
"A poor man has poor ways!"
Old Jun 2, 2007 | 04:00 PM
Hyperactive460
not sure if your still interested but i uploaded some pics of tat front hitch tomy gallery....
Old Jun 2, 2007 | 05:38 PM
79f100six's Avatar
79f100six
if i were you instead of using 1/4 steel. Use 3/8 and it will be alot stronger, the 1/4 probably would be strong enough but with 3/8 you will almost never doubt the 3/8 steel twisting or ripping off.
Old Jun 3, 2007 | 07:21 AM
teds74ford's Avatar
teds74ford
There's pics in my gallery of the one I have. As far as steel thickness, consider that the frame is only about 1/8", so if you "save" your hitch, it might be at the expense of the frame.
joshofalltrades
Oct 3, 2012 06:24 PM
Broughton
6.7L Power Stroke Diesel
Jun 26, 2011 01:56 PM
mudslinging79
Bronco II
16
Mar 21, 2008 07:25 PM
mustange70
Offroad & 4x4
Aug 27, 2004 11:49 AM
TT
All Things Towing
Dec 21, 2001 11:46 AM
