1978 - 1996 Big Bronco
towing with a 96
Old Jul 10, 2000 | 08:05 PM
kb's Avatar
kb
towing with a 96
I have a 96 Bronco 5.0L manual and am wondering about towing with it. Planning to tow a ski boat and all the family fixings. Does anyone know why the stated max trailer weight is 3000lb for the manual vs. 6600 for the automatic? Seems like a large discrepancy.
Old Jul 13, 2000 | 02:58 PM
AlM's Avatar
AlM
towing with a 96
Old Jul 14, 2000 | 08:30 PM
mopitts's Avatar
mopitts
towing with a 96
Automatics are designed so that the torque converter will slip, this allows the trany to tow larger loads. With out a torque conv. a manual receives all the stresses and strains directly. Obviously this is rougher on a clutch than a converter.
93'XLT(NITE)
Old Jul 19, 2000 | 12:17 PM
Chuckybaby's Avatar
Chuckybaby
towing with a 96
I've got an 84, 302 auto, no OD. I tow a 3500 pound fish n ski...tongue weight about 250 lbs. The extra weight at the back raises the front enough to cause the front tires to ride on the outside edge...this results in extreme premature tire wear (price of the spring upgrade is approx = to a pair of good front skins) Also helps with braking (ALOT) if your trailer doesn't have brakes.
Chuckybaby's Avatar
Chuckybaby
towing with a 96
Old Jul 20, 2000 | 03:08 PM
kb's Avatar
kb
towing with a 96
thanks for the reply; front end lift is not something i have considered enough probably. I have considered a weight distributing hitch and a double axle trailer. I don't understand what you mean about it helping if the trailer 'does not' have brakes. This seems the opposite of what I can figure - I don't know if I want to have to shut down truck and 3500lb+ trailer w/o surge brakes. Do you have any experience with this?
thanks again.
kb's Avatar
kb
towing with a 96
thanks for the reply; front end lift is not something i have considered enough probably. I have considered a weight distributing hitch and a double axle trailer. I don't understand what you mean about it helping if the trailer 'does not' have brakes. This seems the opposite of what I can figure - I don't know if I want to have to shut down truck and 3500lb trailer w/o surge brakes. Do you have any experience with this?
thanks again.
Old Jul 20, 2000 | 03:14 PM
kb's Avatar
kb
towing with a 96
thanks again.
Old Jul 21, 2000 | 07:47 AM
Chuckybaby's Avatar
Chuckybaby
towing with a 96
I bought the rig used...the trailer does not have brakes ...it can be very exciting.
If you go with the set-up you describe...load leveler hitch, dual axle trailer w brakes... the only problem you will have is an empty wallet
mssabo
1983 - 2012 Ranger & B-Series
Sep 5, 2013 01:24 PM
Omied
2004 - 2008 F150
Jul 2, 2007 10:07 AM
VanWild
Dec 21, 2003 06:38 PM
califordster
All Things Towing
Oct 11, 2003 02:17 AM
SAR Ranger
All Things Towing
Aug 4, 2003 10:46 AM
