Battery Light On
Old May 18, 2007 | 02:49 PM
jmunkie13's Avatar
jmunkie13
Battery Light On
Yesterday When I Left The House My Battery Light Did Not Go Off On The Dash, The Truck Seems To Be Running Fine, And Starts Right Up??? Any Ideas??
Old May 18, 2007 | 03:07 PM
Izzy351's Avatar
Izzy351
Alternator?? I'll bet if you drive it much longer your batteries will be dead. If you have a hand-held volt meter, you should see about 14V with the truck running and a little over 12 when you shut it down...
Old May 18, 2007 | 03:37 PM
zx250's Avatar
zx250
Of the next Riffraff East
Time for a new Alternator. Get it checked before you ruin your batteries.
Old May 18, 2007 | 04:13 PM
empiretc's Avatar
empiretc
When you say "did not go off", do you mean it didn't turn on when you went to start the truck?
If thats the case, the bulb in the dash may have burned out.
If its constantly on, its time for a new alternator.
Old May 18, 2007 | 04:31 PM
littledre1's Avatar
littledre1
After I got my new alternator put on I also did a trickle charge on both batteries.
Old May 18, 2007 | 05:32 PM
empiretc's Avatar
empiretc
i don't like trickle chargers. they shorten a batteries life.
Old May 20, 2007 | 03:11 PM
jmunkie13's Avatar
jmunkie13
What Is A Trickle Charge......by The Way New Alternator Will Be In Tomarrow
Old May 20, 2007 | 07:48 PM
magnum300's Avatar
magnum300
a trickle charge is a 2 or 3 amp charge. I just put a new alternator on mine and it was the easiest I have ever done, if you have never had the belt off the tensioner is a 1/2 in square between the 2 little pulleys on the left as you are looking at it. please fill out your sig.
