Unused Error Codes????
Old May 18, 2007 | 11:38 AM
PuG's Avatar
PuG
Check Engine light came on and I scanned the system to find these codes:
PO 672
PO 673
PO 674
PO 676
PO 678
The scanner said that they are unused codes. Has anybody else seen this one? I have not had this problem before and have ran the Superchip reprogrammer for years. Any help would be appreciated.
I have a Excurision 2000 with the Powerstroke and I have the computer reprogrammed with the Superchips reprogrammer.
Old May 18, 2007 | 11:46 AM
emptyd's Avatar
emptyd
Question
This is just a guess so take it for what it is worth... If the scanner is only capable of reading "generic" OBDII codes (those common to all manufacturers) it may report "Unused" for any codes that Ford has created.
Since the MIL is coming on, there is obviously something happening. My guess is that your code scanner only has "English" descriptions of the OBDII standard codes, and just pukes out "Unused" when it encounters proprietary codes that Ford has added to the reporting data.
Old May 23, 2007 | 09:55 AM
rlh68050's Avatar
rlh68050
PO 672
PO 673
PO 674
PO 676
PO 678
These are all glow plug circuit faults.
P0672 = Cylinder #2 - Glow Plug Circuit
P0673 = Cylinder #3 - """"" and so on.
You scan tool that you are using isn't capable of reading these because it is just for Generic OBDII faults.
lvin4jc
May 28, 2015 02:23 PM
basecamp
EcoBoost (all engine sizes)
May 14, 2014 08:51 AM
Sieggy
New Member Introductions
Nov 4, 2013 05:10 PM
cornstar6207
Sep 14, 2013 02:34 PM
