Sponsored by: Auxito
pinging problem
Old May 17, 2007 | 03:39 PM
2000 150's Avatar
2000 150
pinging problem
pinging problemhey guys just want to say great site lot of good info helped me out a few times but i have a problem i have a 97 f150 2wd 5sp 4.6 it has a pinging problem it threw out a code for low flow egr i replaced the egr vacum selinoid it put the light out and took away some of the pinging but when you drive on the highway it comes back realy bad but only when you step into it when you step into it.the temp never goes to halfway and the cats dont seem to get real hot.it also has a problem with the rpms staying up between shifts but idles down fine when stoped any info would be greatly apreciated thanks.
Old May 17, 2007 | 03:47 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello and welcome to FTE 2000 F150!
Two things come to mind. Clean the MAF sensor and replace the fuel filter. Good luck!
Old May 17, 2007 | 03:51 PM
2000 150's Avatar
2000 150
did that but thanks
Old May 17, 2007 | 04:12 PM
KingRanchMan02
Is the CEL on now? What was the actual code that you had before? Have you cleaned the carbon out of the EGR elbow?
preppypyro's Avatar
preppypyro
I thought I read somewhere to try using premium fuel... anyone else heard of that?
Old May 17, 2007 | 04:14 PM
KingRanchMan02
Shouldn't have to use premium fuel unless there is a programmer in the truck.
Old May 17, 2007 | 06:42 PM
2000 150's Avatar
2000 150
i cant remember the code number right now but it was for insufficent egr flow and the cel is off. now
Milwaukee1979F150
Oct 4, 2010 12:17 PM
1982_f150
Jul 8, 2007 05:07 PM
Mud Bone
32
Aug 19, 2006 10:49 AM
e g rred
4 Cylinder Engines
Dec 11, 2003 08:28 PM
DruzeTito
13
Nov 21, 2003 03:14 PM
