No Throttle
Old May 17, 2007 | 12:51 PM
loufres's Avatar
loufres
No Throttle
Has anyone experienced lose of throttle after washing thier truck? My truck is an 02' 7.3. Recently and on other occasions, after washing my truck the engine light comes on and the throttle goes away. The truck idles fine but when I push the pedal down nothing happens. I can put it in park, the engine light goes off and then I can rev the engine. Once I put it drive the problem happens all over again. If I wait for several minutes whatever it is that's getting wet dries enough and I can go on my way with no problem. What is getting wet that might cause this? I'd appreciate any help I can get.
Thanks,
Lou
Old May 17, 2007 | 12:57 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
That wierd. Maybe a computer is getting wet
Old May 17, 2007 | 01:43 PM
js139's Avatar
js139
I am definitely not a mechanic, but a place i used to work used Ford Diesel shuttles and when the idle control got wet, the truck would high idle and the throttle was not responsive (much like you indicated). We were able to disconnect the high idle feature and the shuttle worked fine. I know my 6.0 has a high idle feature, but i don't know where the control is. Your problem might be related because the shutle was a 7.3l. Thats all i can think of. Hope this helps
Old May 17, 2007 | 01:51 PM
loufres's Avatar
loufres
Thanks for the reply js139. Every bit of info. helps.I'll gather as much info. as possible and take it from there.
Old May 17, 2007 | 02:11 PM
ryaneverk2's Avatar
ryaneverk2
Thread moved to 7.3L PSD section.
Old May 17, 2007 | 05:10 PM
ron's power stroke's Avatar
ron's power stroke
the PCM and 4 groups of wire are under the brake boost..when they get wet.. strange things happen..you can get some electrical grease and use it on all plugs inside and out..or cover them plugs and the PCM with plastic next time you wash...
Old May 17, 2007 | 05:17 PM
zx250's Avatar
zx250
Of the next Riffraff East
If the engine light comes on, there should be a code stored that may help point you in the right direction. Does the problem every occur when its raining?
Old May 17, 2007 | 05:19 PM
loufres's Avatar
loufres
thanks, I'll start there....at the brake boost.Where exactly is that?
Old May 17, 2007 | 05:25 PM
ron's power stroke
drivers side on the fire wall..big round booster with a white bottle for brake fluid...look down on the inner fender next to the frame and you will see 4 groups of wires..same place but on fire wall you will see a large plug..that's the PCM..
Old May 21, 2007 | 08:32 AM
loufres's Avatar
loufres
Sorry it took so long to reply guys..............yes, this problem only happens when I wash the truck or in heavy rains. I'll check all the plugs leading to the PCM. I plan on taking water hose and statigicly wet certain areas.
Ranger80
Jul 3, 2013 06:38 AM
Alvinmac
13
Nov 22, 2010 01:31 PM
427ford
May 9, 2009 12:29 PM
ryme4reson
2004 - 2008 F150
Jan 22, 2009 07:36 PM
TigersGrowl
1978 - 1996 Big Bronco
Nov 8, 2003 05:54 PM
