Sponsored by: Auxito
F150 Brake Lines
Old May 17, 2007 | 12:14 PM
Thomas Hutchins's Avatar
Thomas Hutchins
F150 Brake Lines
Just lost the metal line on my 97 F150 (103500 or so), from Master Cylinder to left rear wheel well and I assume the other llines are in poor condition also.
Question, are sets of pre-bend lines available for a '97 f150 or do I use roll lot tubing and double flare the ends?
Old May 17, 2007 | 04:15 PM
KingRanchMan02's Avatar
KingRanchMan02
You will most likely have to bend up your own.
Old May 17, 2007 | 05:10 PM
steve(ill)'s Avatar
steve(ill)
on any truck, i normally measure the total length, then figure out how to assemble it out of 2-3-4-5 footers so the joints are out in easy assembly areas under the truck. you can bend and route a 4-5 ft piece thru the frame rails much easier. they come pre flared and you buy connectors from Auto zone.
