C-6 Problems
Old May 17, 2007 | 11:12 AM
72_po481's Avatar
72_po481
C-6 Problems
I have a C-6 in a 72 f-250. i bought the truck several months ago and it was not running when i did. the previous owner claims he was driving home from walmart when the truck quit and that he had not driven it since. i got the motor working but now the transmission is acting really wierd. it has 1st gear no matter were the shifter is placed. i replaced the modulator as it had trans fluid in the line but still the same thing. The previous owner claims he rebuilt it. my next step is to rebuild the transmission again but if anyone could shed light as to what might be wrong i would really apreciate it.
Old May 17, 2007 | 02:40 PM
stuart1's Avatar
stuart1
Drop the pan and look at the manual shift valve.
It could be disconnected.
Old May 17, 2007 | 03:16 PM
72_po481's Avatar
72_po481
Ive already taken out the valve body. it never crossed my mind so i didnt check. thanks for the reply.
Old May 17, 2007 | 05:27 PM
stuart1's Avatar
stuart1
If the valve body is out now is the perfect time to do an air check.
If the drums and servo hold air the transmission has to work.
Old May 18, 2007 | 02:55 PM
72_po481's Avatar
72_po481
I'll give it a try. thanks
Old May 20, 2007 | 05:29 AM
79f150toy's Avatar
79f150toy
what about the linkage? so youre saying that you start it in first gear... or it wont shift out of first....no reverse, neutral, and park?... or is it a problem with the forward gears?... im unclear of the symptoms...
Old May 20, 2007 | 04:38 PM
72_po481's Avatar
72_po481
I'll start the truck with the shifter in the park position but it is in first gear. if it is placed into reverse or any other gear it still remains in first. so the truck only goes forward and there is no upshift into second when it is driven in drive. so basically it wont shift out of first.
Old May 20, 2007 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Take a look where the shift rod attaches to the selector lever on the bottom of the steering column and follow the rod to the manual control lever on the left side of the transmission. Both locations have bushings, the one on the m/c lever is a snap in. If the bushings are missing, the rod will flop around and won't properly engage the trans. The steering column selector lever bushing (C5TZ-7343-A) is still available from Ford, the m/c lever snap in bushing (C8OZ-7341-A) can be gotten from NAPA
78F150RangerXLT
Mar 22, 2009 01:56 PM
Roger Davis
Nov 23, 2007 03:21 PM
fuddy
Aug 26, 2007 02:08 PM
macwilj
Jul 28, 2007 08:26 PM
randy332
Mar 8, 2007 06:47 AM
