noise in engine after shutdown
Old 05-16-2007, 07:03 PM
sponge's Avatar
sponge
sponge is offline
Red face noise in engine after shutdown
Just traded my 2000 7.3 for a 2005 6.0 a couple weeks ago. So far I really like my "new" truck. My question is when I shut down the engine there's something that sounds like a pump or something that runs for 10 or 15 secs before it shuts off. I talked to another guy with an 05 who says his doesn't do this. Any ideas what this might be
Old 05-16-2007, 07:07 PM
vloney's Avatar
vloney
vloney is offline
Sounds like the "buzz" flash. It cycles the injectors after shutdown to purge them of oil to prevent stiction.
Old 05-16-2007, 07:24 PM
sponge's Avatar
sponge
sponge is offline
Thanks. I did read about that on another post and thought that might be it. Just wanted to hear what you'all have to say
Old 05-16-2007, 07:28 PM
msgtg's Avatar
msgtg
msgtg is offline
Yup, I have an 03 with the 6.0 and I get the buzz before start and after shutdown.
Welcome to the site!
Old 05-16-2007, 07:32 PM
vloney's Avatar
vloney
vloney is offline
The buzz before start will probably be the vacuum pump.
Old 05-16-2007, 07:57 PM
50jd60's Avatar
50jd60
50jd60 is offline
Had the same thing on the 03 and now the 05 after shutting down, mine is the turbo coasting down, all stock
Old 05-16-2007, 08:37 PM
origcharger's Avatar
origcharger
origcharger is offline
One should refrain from getting a buzz before driving.
Old 05-16-2007, 09:22 PM
a-rod's Avatar
a-rod
a-rod is offline
Sponge, if you dont like the buzzing, which some dont, theres a newer flash out that gets rid of it, and uses a different measure to accomplish about the same thing (stiction issues). Some of us are sticking with the buzz flash, but so far I havnt heard anything bad about the newer one, (Inductive Heating). Do a search and you can find a lot more about them if you want.
