Torque converter
Old May 16, 2007 | 01:36 PM
FF180's Avatar
FF180
Torque converter
Hey guys i am thinking of replacing my torque converter myself i was wondering if any of you could tell me what id be getting into if its like really hard or what the truck is a 1993 F-350 4wd diesel 4-door thanks for any help
Old May 16, 2007 | 02:12 PM
David85's Avatar
David85
You will have to drop the trans, thats pretty much the worst of it (electrical connectors, cooler lines, drive shaft). You should also drain TC before pulling trans.
When you remove the TC, the lockup shaft may try to come with it, but if it does, it can only be reinstalled one way. Lifting the TC enough to take weight off the stator may prevent the shaft from snagging.
The torque converter on the E4OD will hit three notches as it engauges the pump seal, lockup shaft and then the pump gears. I would take a reference measurement of the offset difference between the TC mounting face and the bellhousing mounting surface. That way, you'll know when the new one is in all the way.
Old May 16, 2007 | 02:36 PM
brownieboy525's Avatar
brownieboy525
the job is fairly simple but comes with a few snags. The e4od is a very heavy unit your definalty want to think about a transmission jack. First drain trans remove plate covering converter drain converter. remove drive shaft then you can pull the transfercase from the trans or leave the together ( i like to pull the transfer case seperate). then undo eletrical and i think that you have to pull the starter but not 100%sure. you then have to unbolt the converter fromt the flywheel there are four bolts.then you can unbolt the trans from the motor (dont forget the top two bolts lol). the converter will come down with the trans.
Old May 16, 2007 | 06:32 PM
FF180's Avatar
FF180
Well thanks for the help iam not all that farmiliar with this truck tho i havent worked on it yet so iam not to sure if iam goina get into all that also hoiw would i know that its the trans. the e40d i think you said thanks.
Old May 16, 2007 | 08:58 PM
David85's Avatar
David85
The E4OD is the only automatic transmission avalable for that year of diesel ford truck. Some say the C6 was optional, but I have not been able to confirm this, if you have overdrive, its not a C6. Shifter should show P RN(D)21 with (D) being overdrive, and a cancel switch to limit the trans to 3rd gear when needed.
Any reason why you want to replace TC?
Old May 16, 2007 | 09:12 PM
Winger235's Avatar
Winger235
1986 last year of the 4spd manual. 1987 was ZF-5. 1988 was the last year of the C6. 1989 was 1st generation E4OD. 1990-1991 2nd generation with multiple changes in wiring harness and transmission control box. 1992-1994.5 Same transmission with possible torque converter updates for the turbo models more electrical updates and wiring harness changes.
Old May 16, 2007 | 10:13 PM
archangel's Avatar
archangel
The C6 was an available option, but for fleet sales only I was told.
I rebuilt enough of them when they first come out, and I saw all the weak points.
Old May 17, 2007 | 03:45 PM
FF180's Avatar
FF180
Well once again thanks guys um i think the tc is going bad i have been having problems with the truck this year that i thought were all fuel related however i replaced the fuel injection pump and lift pump air and fuel filters this did fix most of the problems but theres still sumthing wrong its hard to start hot and cold (worse when Cold) and it kinda stutters like it wants to stall separt problem i think from this, its also jumping when in gear sometimes so i thought that the tc might be part of the problem any ideas are appreciated.
Old May 17, 2007 | 03:47 PM
FF180's Avatar
FF180
O and if the C6 was avalible could it be in my truck because it was bought from a fire department so it would be fleet sales. Also how could i find out does it say on it.thanks
Old May 17, 2007 | 03:52 PM
David85's Avatar
David85
Jumping in gear. When and how is it doing this? Is it in park, or are you driving while this happens? Does it stall when you come to a stop while still in gear?
Old May 17, 2007 | 03:54 PM
David85's Avatar
David85
Check my earlier post for how to identify a C6 from E4OD.
Old May 20, 2007 | 09:13 PM
FF180's Avatar
FF180
thanks guys um it is jumping when in drive or reverse when ur stoped like at a red light or just before backing out of the garage and yes it does stall sometimes when you come to a stop at a light/ also I noticed to day when you tromp on the gas theres black smoke coming out this may be normal i dont know much about diesels yet just got into them at 19 haha it gets worse if you pull out on a hill. trucks all stock so thats y iam not sure its normal thanks again iam learning alot
Old May 20, 2007 | 09:29 PM
David85's Avatar
David85
The TC clutch could be engaging and/or staying on when its not supposed to (as I think you already suspected). Have you tried to pull any fault codes?
Some black smoke is to be expected, but you may be seeing more than is normal with the TC keeping the revs lower than usual.
Old May 21, 2007 | 04:00 PM
FF180's Avatar
FF180
well thanks for the help once again it went into the shop today so woll see wuts going on with it ha ill let you now thanks.
Old May 21, 2007 | 06:08 PM
Winger235's Avatar
Winger235
I would suspect a E4OD if your having that trouble. C6 torques have no lock up clutches.
