I have a 2003 ford superduty
the problem i am having is that the flasher for the blinkers and hazards is buzzing as soon as you turn the key on if you touch the brake or turn the hazards on or a blinker it quits till you turn them off or let your foot of the brake I tryed a new flasher and it clicks under the same simptoms no buzzing
what do you think it could be I am frustrated I can't figure it out
Same prob a while back, and unfortunatley replacing the flasher doesnt help but what ive searched on here is found out that the wires going to the turn signal handle assembly are just a bit too short, its inside the cover of the steering colum. You could pull it apart and see if its almost unplugged, to tight on the wires caused mine to do it. Thats what fixed mine, i just pushed and pulled around on the wires until it quit Otherwise you have to get the whole assembly i cant remember but it wasnt a nickel
thanks i pulled the little thing that holds the flasher out and played with the wires and it stopped so maybe i will leave it like that for a little bit thanks for your help
I had know idea what to do
thanks again
Rusty
