Check Engine Light-code 1396
Old May 15, 2007 | 04:04 PM
victorio91306's Avatar
victorio91306
Question Check Engine Light-code 1396
<TABLE><TBODY><TR><TD vAlign=top width="100%">I would appreciate advice regarding the list attached to a recent scan that suggest possible reasons why my CHECK ENGINE light is illuminated.
The list of POSSIBILITIES, (for the code 1396), is:
Faulty glow plug relay
Faulty glow plug shunt
Open in glo plug circuit
Faulty glow plug
Faulty power train control module
My 1997 7.3 powerstroke with 165,000 miles seems to be running just fine.
Please, if you could offer some sound advice so I can do the right thing.
Thank you Kindly,
Victor
</TD></TR></TBODY></TABLE>
Old May 15, 2007 | 05:50 PM
Cuda_jim's Avatar
Cuda_jim
Is the Check engine light illuminating?
Those may be old codes that were not cleared after a repair. If the truck is running OK don't worry about it.
Pull #9 fuse under the hood. This should reset the codes. IF not disconnect the batteries for 30 minutes or so.
Old May 15, 2007 | 06:34 PM
10bands's Avatar
10bands
Check out your glow plug system. Here's some info on how to do it.
https://www.ford-trucks.com/forums/5...-ohm-test.html
and
https://www.ford-trucks.com/forums/4...ke-thread.html
Steve Combs
Apr 29, 2015 02:01 PM
kcchief434
Feb 12, 2009 08:21 PM
fordkev
3.8 & 4.2L V6
Feb 9, 2008 06:33 PM
Roger Davis
Nov 23, 2007 03:21 PM
72_po481
May 20, 2007 04:52 PM
